ideal location for wet nozzle on intake piping
So far searches have mentioned how far away from the throttle body to mount the nozzle for a wet system and that the best location is for the nozzle to point at the center of the throttle body. However those 2 bits of information conflict with each other in my situation.
-Suggestions have been 18-24" from the throttle body but that would put the nozzle way down low and out of view from the throttle body. Please help me out here.
Is the red blob I drew the ideal location? I will be using the NX proton plus kit with the shark nozzle as in the picture.
Mine's not too far off from your setup. Drill your hole just off the inside radius of the tube, and don't be afraid to notch the coupling a bit like mine.
Attachment 722136
Attachment 722136
Ok and just to confirm, it seems like you guys are recommending the nozzle be placed lower down on the same length in the pipe as opposed to the top of the intake pipe, in the context of both being the same distance from the throttle plate but the lower location is ideal. Is this because placing it up top like my red line doesn't distribute the mix as well especially considering this is a truck intake (so it's taller)?
I went for mid-line in height mostly because it's easier to eyeball if it's pointed straight at the throttle blades or not. I wouldn't place it where you marked because you want to get it closer to the throttle blades and try to get it on a straighter piece of pipe to avoid spraying the walls of the intake tube. You want to shoot it straight down the middle of the pipe... But...I'm not an expert...
