how much fuel pump do I need if running a stand alone?
motor is a built 370, nitrous cam, 10.8:1 compression, mamomotorsport 235 heads, vic jr, stinger plate, accufab 4150 tb. The build is not finished yet but If Im running a stand alone for my nitrous fueling would a single walboro 340 surfice? Will be running on pump gas maybe race gas instand alone on occasion
Single Walbro 255 intank Fuel pump is good for 650 HP. Max.
I have an LS2 404 ci. Stroker Nitrous Motor that makes around 650 HP on the Juice with a 150 Shot of Nitrous. Im not running a stand alone. The Single Walbro 255 supplies all of the Fuel for my motor & nitrous system. I am Maxed out now at 650 HP.
You could always run Dual Walbro 255's if you modify your fuel pump bucket. Make sure you run the upgraded Racetronix Fuel pump harness & relay with the 255 Walbro for safety & max fuel pump performance. Lonnie at Lonnies Performance is the Guru on Fuel systems. He is a sponser on this LS1 Tech site. http://www.lonniesperformance.com/
Stand alone Fuel system along with the Single Walbro 255 intank pump would be the way to go at 700-800 hp.
They say Low Fuel pressure supplied from stand alone works best with the nitrous system.
A stand alone will continue with a fuel pump. Usually a walbro 255 or if low pressure a Holley blue or something.
My car makes 570rwp on motor with a single walbro 255. Spray 200 on top of it with a stand alone that has a walbro 255.
I have twin walbros in the tank from when the car was procharged a long time ago. Before j bought the stand alone I had the second pump to come on when the nitrous was activated. Worked fine. But was only spraying a 150 shot. Never went lean or dropped fuel pressure.
