11.7?
Old 12-13-2015, 04:15 AM
fayettevillin's Avatar
Default 11.7?
I ran today da 1300... 11.7@114 on 150shot plate 3800stall headers ory borla lid
1.60 60ft
7.48 1/8@90...what do you guys think?
Old 12-13-2015, 08:11 AM
JoeMama's GTO's Avatar
Probably need some more details like car type, weight, engine, you know the minor details to help make a guess based judgement on your time.
Old 12-13-2015, 08:37 AM
mjs1012's Avatar
Is this in an fbody?
Old 12-13-2015, 09:45 AM
HCI2000SS's Avatar
Yes more details would be helpful
Old 12-14-2015, 05:39 AM
Yes 99 Camaro full weight on dr I'm about 265... I figured "lid" would be a dead give away for a fbody
Old 12-14-2015, 07:13 AM
HCI2000SS's Avatar
The mph seems a little low to be honest. What did it trap n/a?
Old 12-14-2015, 01:38 PM
Last time I went 11.8@116 put 28" fronts on dropped .1 et and 2 mph
Old 12-14-2015, 05:21 PM
tnmotown's Avatar
Yeah the MPH seems a little low considering a 150 shot. Has the car been tuned at all? How much timing is being pulled when spraying?
Old 12-15-2015, 09:36 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Definitely not bad at all, but I bet there is still some left in the tune!
-Chris
Old 12-15-2015, 10:50 AM
AJatNitrousOutlet's Avatar
What's some details on your build? Auto or Manual?
Old 12-15-2015, 10:53 AM
Originally Posted by AJatNitrousOutlet
Auto or Manual?
I assume with a 3800 stall it's an auto....
-Chris
Old 12-15-2015, 11:53 AM
-Chris
True, did not see that one-
Old 12-16-2015, 02:37 PM
Dirty Vegas's Avatar
1.60 60ft
Something ain't quite right. Are you sure the nitrous is coming on? What does the car run on motor? My N/A stock internal 99 Camaro went 11.68@113, with similar DA, Yank SS4000, and OBX headers. At this point, you'd probably cry if I told you what it went on the gun. What brand plate are you using? Complete new kit or scrapped together old parts? Plugs? Fuel Filter? Maintenence?
Old 12-16-2015, 09:05 PM
built 4l60 on a 3800 circle d, ls6 intake custom lid, ported maf and tb lt headers ory and borla exhaust.. im just flashing the conveter and hitting 1.60 60' hiting right n20 right after I start rolling I stalled it up and I just light up the hoosier drag radials.. I do the tune myself and I have a fti street sweeper cam waiting to go in just haven't got time but the tranny went so I threw the stall in when I had it rebuilt and added a cooler.. I got a friend that's going to look at my tune and adjust hes got a 9 sec s10.. im running a nos brand plate new br7 plugs new msd wires new filter oil battery lol
Old 12-18-2015, 12:47 AM
Ok, let's get this bitch figger'd out.
Step 1. Throw that junk *** plate in the nearest garbage can. I've never seen anyone run an impressive ET with that turd. I had one. It worked like complete dogshit.
Step 2. Get a real tune. What wideband is installed on the car?
Step 3. Buy another stock MAF sensor. Ported MAF's cause more tuning problems than they solve. Do you know how much air is flowing past the MAF now? No! Either does your ECU.
Step 4. Figure out your traction problem. You shouldn't be "lighting up" Hoosier Drag Radials. Do you have any suspension work? If no, why the hell not? What about track prep?
What "custom" lid are you using? Is it garbage?
I wouldn't put the cam in until you get it running well. As I and others in this thread have asked, what does the car ET on motor? Telling us the spray number doesn't do much good without the baseline ET on motor.
Old 12-18-2015, 02:44 PM
high n dry's Avatar
Lol... I like where this guy's head is... he's on point!
Old 12-18-2015, 05:11 PM
blk00ss's Avatar
Yup. What they said. I had a NOS plate too. ******* sucked.
Old 12-20-2015, 10:01 AM
98z28jorge's Avatar
I had a nos plate and never had an issue you just have to play with the jetting their recommended jetting is pig rich I went 10.30s with a nos plate on a 150 shot btw once you go higher is when they start to fall off but make sure you check the timing and fuel don't go off wide band check the plugs
Old 12-20-2015, 11:48 AM
blk00ss's Avatar
Mine had a bad lean spoke on the hit I could never get rid of.
Old 12-20-2015, 12:02 PM
My old car with the NOS Plate, 950 bottle psi, recommended jetting for 150. 11.51@119
My old car with 224 cam and Nitro Dave's under the lid halo dry bar without a jet, but with 650 psi 10.60@128 shifting into 4th!!!
