Non resistor plugs with lingenfelter box.
Wanted to know if anyone who using the lingenfelter box to pull timing runs non resistor plugs? Can not find any resistor plugs colder than a 7, and lingenfelter recommends running resistor type only.
Thanks.
Thanks.
Lingenfelter recommends using the resistor type plugs because the non-resistor type can cause interference. We have had great luck with it and never ran into an issue with the NGK B8EFS and other plugs, but you want to use some good noise suppressing plug wires with it.
LS1Tech Sponsor
Resistor plugs
The TR7 plug is roughly the same heat range as the Denso IT22 plug.
Staying in an NGK plug a TR8ix exists that is one heat range colder than the TR7 (and the TR7ix which is the NGK iridium version of the TR7).
IT24 and IT27 resistor type spark plugs are available from Denso.
The IT24 is similar in heat range to the R5724-8 from NGK.
The IT27 is similar in heat range to the R5724-9 from NGK.
As an additional reference point, the production LSA/LS9/LS7 plug is an AC Delco 41-104 iridium plug. It is similar to an IT20 in heat range which is about the same as a TR6.
I looked into the wires i have and they have a good rating for noise cancellation. I'm sure i will run ngk, because that is what i was running before the lingenfelter box. Thanks again for all the replies.
LS1Tech Sponsor
Plug wires
We have had very good results with the OEM wires and with the Magnecor wires.
http://www.jegs.com/i/Chevrolet-Perf...95519/10002/-1
these are the plug wires im running with br7ef plugs is it a good combo for the lnc-2000
LS1Tech Sponsor
Iridium plugs
Could you explain/clarify your reasoning for this?
We ran a 500 shot of nitrous on our 427 CID LS9 supercharged 2010 Camaro SS with the Denso IT27 plugs without any issues.
The GM production LSA/LS9/LS7 plugs are also an iridium plug and many people use these with spark plugs with nitrous.
Race your car!
LS1Tech Sponsor
BR7EF spark plugs
The BR7EF spark plugs are a resistor plug so they should be fine from an electrical noise standpoint.
They are a NGK 7 heat range.
You can usually find the specifications on the NGK plugs on the NGK web site here:
https://www.ngksparkplugs.com/
or directly here:
http://www.partcat.com/ngk
Be careful trusting the data on other web sites (non manufacturer web sites). I frequently find heat range, resistor configuration etc. errors for spark plugs on major web store sites.
or directly here:
