N2O solenoids chatter once
Old 03-18-2017, 07:57 PM
stratass's Avatar
Default N2O solenoids chatter once
They chatter once and will not work on second attempt. I have to turn the ignition off and back on for them to activate again. wot switch and a thumb switch on the shifter. What do I need to check. Nitrous is off while doing this.The purge works ok ,its on its own relay.
Old 03-18-2017, 08:07 PM
stratass's Avatar
My wiring diagram.
Old 03-18-2017, 08:15 PM
tug686spd's Avatar
Try switching the n2o and purge relays and make sure grounds are good and secure. I chased a similar problem for 2 days and it ended up being the relay. It would test out fine with a test light but as soon as some real curent went through it it wouldnt work.
Old 03-19-2017, 05:03 AM
baronsmith98's Avatar
The fuel safety switch should not be run on the ground for your solenoids. Run it off the 85 terminal on your relay.
Old 03-19-2017, 07:14 AM
stratass's Avatar
Thanks for the replies. I think the solenoids are staying open and that's why there is no repeat engagement until ignition is turned off. I will try your suggestions.
Old 03-19-2017, 09:50 AM
stratass's Avatar
I bypassed the fpss and it works as it should.
Old 03-20-2017, 03:09 PM
brandon@nitrousoutlet's Avatar
I would recommend putting an interrupt relay into there so that the nitrous and 2-step can't come on at the same time. You will just use a 5 pin relay and wire it up like a trans brake interrupt. If you tried to activate the 2 step with the nitrous armed, you're going to have a mess on your hands.
Old 03-27-2017, 01:23 PM
AJatNitrousOutlet's Avatar
You may need to adjust the FPSS if it works fine while unplugged. What may be happening is the FPSS is set to a point at which the pressure drop on the rails when the solenoid opens causes the FPSS to open and kill the power.
Quick Reply: N2O solenoids chatter once
