Bolt on LS1 + TnT 150 Wet Shot. What to Expect?
I plan on running a TNT 150 wet shot on top of the current mods in my sig. Anyone have any similar setups? what kinda numbers should i expect at the track?
i went 11.54 @ 116mph w/ 1.58 60ft. with the following:
MTI lid, 3200 Vig stall, hooker catback, TNT100 shot, MAF Translator, 16" e.t. streets
3280lb raceweight
i think that automatic helped out with the launch compared to where you'd be without blowing the 10 bolt. SO i'd say that you could very possibly be in the mid-high 11's depending on how well you can drive. let's give that a "perfect run" guess.
3280lb raceweight
Originally Posted by 10secopcar
ya id say what he said low 12s to high 11s
SlowZ28, no offense and again I could be wrong but those numbers seem really poor for a 3280 race weight. that car is stripped! I'd think your MPH in particular would be higher and traps would be lower.
Maybe i am misuderstanding something about N20. Do n20 dyno numbers not equal the track performance of NA dyno numbers, generally speaking?
slow z28 is an auto so rwhp is probably around 400 so his times are close.with those bolt-ons & a 150 on a m6 it should trap 122-125 in the 1/4 but traction is the main hindrance for a manual.
I dynoed 456 rwhp and 533 rwtq with TNT 100 shot mti lid, macs, hook muffler, vig 3600, and tune. My best run in the 1/8th was 7.17 @90 1.50 60' with a messed up 2-3 shift.
My best run with TNT 150 Shot, SLP LT's, K&N FIPK, Motive 4.10's and BFG Drag Radial's last year was an 11.07 @ 126 but could never back that up it would consistantly do 11.3's @ 123-125 with 1.7 60". Gear's and some tire's beside's nitto's and I am thinking 11.3's-11.6's is possible. Gear's would really help.
Intake, exhaust, test pipes, MT ET Street radials. 125 dry shot, I pulled constant 11.5's my first time at the track. Automatic with 323s. Mines also a hardtop if that matters.
Originally Posted by KB99WS6
Yeah, just like I was saying....low to mid 11's, not mid 11's to low 12's...
and thats how high u r above sea level.
where im at n oklahoma cars have gone to ennis texas and dropped half a sec between the altitudes. But i was sayn what i said based on cars here.
so u might very easily be mid 11s wont ever no till u go to track and find out
sorry, should have been 3380(type too fast) car's not gutted completely, i'm a skinny bastard, i probably weighed 150 then(2001). maybe the weather was horrible(usually is up here) i dont' know. then again it's only lid/catback/small converter/100shot. stock '98 exhaust manifolds and cats, stock 3.23's, stock LS1 intake, stock TB, stock maf, no "tune" other than HPP for shift points. Where should I have been? I DOUBT the car would have dynoed anything close to 425rwhp
Funny thing is i took the nitrous off, swapped the converter for a TP4400 and went 11.74 @ 115mph.
I'm a decent driver too btw. I can pull consistent 1.8 - 1.9 60's on my stock 16" rims w/ Nitto Dr's. So also what kind of hp and tq numbers should my car put down w/ a 150 shot? Would i be safer running a 100 shot because i really don't wanna blow my motor any time soon, but i 've heard of a lot of people running a 150 shot fine on a basically stock LS1 motor.
i had lid/cutout and 245 nittos.. and 89$ lakewood control arms and i ran 11.63 at 122.8 with a 2.29 6f0t and a 7.70 1/8th.. my best 1/8th at the local track was 7.42 with a 1.89 60ft tho.. so i think i could have netted low 11's, especially since i installed macs mids and a 3000 converter i think id have been close to 10's with good tires.. sorry i cant be of more help i got impatient and put my cam in tonight so..
but my car was a non option car from the factory, and it was pretty damn light the way it came.
