Where can i put my switches?
I have a Vert so Im kind of running into a problem. Where can I put my switches for the nitrous and purge? I have a Vert so I have the top button and also have TCS button in the most common places. Anyone have any ideas? Thanks
Brian
Brian
Brian
Brian
not familiar with line lock switches but the jimmy jams ashtray plates have 4 toggles and a momentary button for m6's...would you be able to wire your line lock on a setup like that? -momentary for purge, toggle 1 to arm system, toggle 2 for heater, toggle 3 for remote opener, toggle 4 for line lock?
I'm sorry but those switches do not look factory.....
If you need more space than what the ash tray can provide and want to keep your system as discreet as possible I suggest getting 2 factory fog light switches and putting them up in the trim above the radio.
I have the Jimmy Jams ashtray switches..put my n20 purge, arm switch, line lock, and bottle heater....got one extra swicth for the bottle opener later on down the road...
Do the switches on the jimmy jams light up to let you know when they are activated?
http://www.jimmy-jams.com/
and a pic of the one for the Manual
have the following switches in the ashtray (also running a vert)
arming switch
purge switch
bottle warmer switch
bottle opener switch
electric cutout switch
line-lock switch
arming switch
purge switch
line-lock switch
