Disappointed w/ Nitrous numbers
Old 04-30-2005, 11:23 PM
RED98WS6's Avatar
Default Disappointed w/ Nitrous numbers
Had my ws6 on the dyno today and ran 375 rwhp NA, then ran 445 rwhp w/ 150 wet shot. I'm thinking w/ 150 shot, I should have put down 500+ rwhp. The jet size was #62 (N2) and #33 (fuel). This should be the full 150 shot.
I running stock injectors. I'm thinking this may be the problem. Probably need 42# injectors along w/ a high pressure fuel pump. What do you guys think?
Old 04-30-2005, 11:31 PM
Beast96Z's Avatar
Fuel pump and injectors can't hurt. The nitrous system is prolly placing to much of a strain on the stock pump. I would look into that before the injectors. If you can find someone with a scan tool, you can check the duty cycle on the injectors to see if they are being over worked.
Old 04-30-2005, 11:50 PM
RED98WS6's Avatar
Hey, thanks alot!!!
Old 04-30-2005, 11:56 PM
RED98WS6's Avatar
Hey Beast 96Z.....I noticed in your mod list you've got the Bogart wheels. When I get some 15" rims and slicks I'm thinking about Bogarts. I heard that you don't have to grind the calipers when you use Bogarts which is the reason I want them. Just don't want to pay the $$ for them. But I'd rather that than grind the crap out of my calipers.
How do you like your Bogarts?
Old 05-01-2005, 04:16 AM
Wile_E's Avatar
Your injectors should be fine since you have a wet kit.
What was your A/F like on that run?
Old 05-01-2005, 05:42 AM
Formula1999's Avatar
Do you have a bottle heater?, if so check the pressure.
Old 05-01-2005, 09:19 PM
12 Second Truck Club
Magic Chicken's Avatar
what kind of kit do you have?
Old 05-02-2005, 10:04 PM
RED98WS6's Avatar
NX 150 shot (wet kit)
I took the jets out today to make sure they didn't get switched around.
They are correct. #62 for N2 and #35 for fuel. I also took the nozzle out and made sure it wasn't clogged. Everything checked out ok.
I also am running about 900 psi bottle pressure. I know it's alittle low, but shouldn't make that much difference.
I am stumped. Any ideas would be appreciated.
Old 05-02-2005, 10:06 PM
RED98WS6's Avatar
I didn't get an A/F reading.....
Old 05-03-2005, 10:36 AM
slow trap's Avatar
you should have hit an easy 500.i went from 383 to 513 with my nx maf wet kit and that was with 6* timing took out and richened up to 12:0.stock pump also.1050 psi pressure.you definitely have a problem,check your a/f ratio next time and timing.it could be pulling time but still should have picked up 100 +.
Old 05-03-2005, 01:22 PM
Turo's Avatar
Originally Posted by RED98WS6
...I also am running about 900 psi bottle pressure. I know it's alittle low, but shouldn't make that much difference....
You would be amazed what a difference bottle pressure makes. Try going up to ~1000 next time (I run mine at 1050-1100), and re-dyno. Remember, the pressure drops down quite a bit once you hit the spray.
Old 05-03-2005, 02:22 PM
LS1 Tech Administrator
Patrick G's Avatar
Yes, something's wrong. With .052 jets (100 shot) on my NX MAF kit, I picked up 99 rwhp with stock manifolds, cats and closed exhaust. My bottle pressure was only 900 psi (since I don't have a heater yet).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 05-03-2005, 04:36 PM
Nitro Dave's Nitrous Outlet's Avatar
You may be a little rich.NX is now using 62/33 for the 150 shot.
You really need to know the air fuel.
Dave
Old 05-03-2005, 06:02 PM
RED98WS6's Avatar
Dave
Hey, thanks alot guys. I will get an A/F soon!!!!
I will also try heating the bottle to 1050 psi.....
Old 05-03-2005, 06:53 PM
next's Avatar
I'll take a stab here - I'd suggest you get a meter and find out how much power you're getting to the solenoids. You'd be surprised how low voltage will run the 'noids but not fully open.
Old 05-03-2005, 09:48 PM
RED98WS6's Avatar
You know, I thought about that today.....could be my solenoid being the restriction for some reason. Also, I probably shouldn't rule out my pressure gage being off (too high) reading 900 when it could be less....
