How many shoot off the line?
Old 06-01-2005, 05:22 PM
Lady Redhawk's Avatar
Location: sojourning....looking for my city whose builder and maker is God.
Default How many shoot off the line?
At the track how do you guys engage your nitrous? I tried an 100 shot with a 3,200 pill and it blew up my rear end and my tranny!
Old 06-01-2005, 05:51 PM
Dustin's Avatar
I have done it once with 100 shot, stock converter, nitto 555r extremes, and i couldnt get traction worth a bitch so i dont do it till second now
Old 06-01-2005, 05:56 PM
I was running ET Streets Drag Radials and had some wheel hop, that is what tore up both my rearend and tranny.
Old 06-01-2005, 07:02 PM
12 Second Truck Club
Magic Chicken's Avatar
I have a 2800 stall, progressive controller setup to start spraying 60% power at 2000 RPM's ramping to 100% power in 2 seconds shooting a 175 shot. Have had no problems except traction occasionally, but it's a little harder to get traction in a 2wd truck.
Old 06-01-2005, 07:10 PM
crAzy95Z28's Avatar
i shoot right off the line at 3k thats when the window switch kicks in...
3k-6k
have had no problems..
but need to change my tranny fluid now cause 1st-2nd are shifting slow now. SHould be hitting hard cause of the shift kit.
Old 06-01-2005, 07:15 PM
badass 2002 z28's Avatar
150shot right off the transbrake...
Old 06-01-2005, 07:25 PM
next's Avatar
Oh yeah, off the line
Old 06-01-2005, 07:41 PM
Navy David SS's Avatar
Recently 150 shot. I have done 200 shot right out of hole off the transbrake.
See my (and next's) picture in signature for what can happen
David
Old 06-01-2005, 08:12 PM
mike c.'s Avatar
i dump the clutch and when it hits the floor the juce comes on. i gained .3 more when i spray off the line. i think i may see what a 200 shot will do this year OFF THE LINE
Old 06-01-2005, 09:02 PM
Ben R's Avatar
400 off the brake. Went a 1.24 60' time.
Old 06-01-2005, 09:06 PM
JobeZ28's Avatar
What about a stock A4 camaro, with a 100 shot off the line?
Old 06-01-2005, 09:08 PM
Ben R's Avatar
Don't dead-hook and don't spray through the shifts.
Old 06-01-2005, 10:04 PM
mrr23's Avatar
it'll be slower than when i first used 200 on my stock a4 formula with only a slp airlid at the time. 11.97 with a 11.99 next run. hit it at 2000 rpm first gear on regular 275/40-17 sumitomo tires. oh, and sprayed through the shifts as well.
Old 06-02-2005, 01:34 AM
35th SS's Avatar
125shot out of the hole.our track sucks though.
Old 06-02-2005, 01:53 AM
Robert56's Avatar
Wheel hop is expensive. Try progressively getting to wot to maintain traction till you can handle the added torque/n2o power, or first gear lock out on n2o. Also upgrading suspention to eliminate wh. I get it also sometimes when getting to aggressive on launch.
Old 06-02-2005, 07:54 AM
Restricted User
2001 Pewter WS6's Avatar
I wouldn't recommend hitting a 100 or 150 shot at 3000 rpm. That is a hole lot of stress on those rods from the torque. I had my pills set at 3800. I had a friend with a Z06 used to hit it at 3000 and not long after put a rod out the the side of the block.
Old 06-02-2005, 08:19 AM
Ouch! Don't want that to happen!
I was looking at my last all motor run scanning with EFILive. I am almost to the 60' mark at 5,000 rpms and going 30 mph. If I get my tranny working good again, I thought about putting in a 5,000 or 5200 rpm pill. My rpms never drop below that again through the rest of the run.....Anyone try that?
Old 06-02-2005, 10:07 AM
next's Avatar
If you really want the best ET performance you'll be launching on the gas. 40% of your elapsed time on the track will be spent from the 0 - 330 mark which is only 25% of the total track. You'll make the biggest gains in dropping your ET by focusing on the most power the soonest. I don't see the logic behind the comment not to use a 3000 pill.
Old 06-02-2005, 10:46 AM
Robert56's Avatar
Agreed, however, some of us are not at the point of putting all the power available to the ground, yet, and get a spectaculer 1.3x 60ft'er. I use 3500rpm for first stage and 4700rpm for second stage in 2nd gear because I can't handle it all traction wise and looking for longevity in running gear also. A friend is doing a 12.09 and 1.9x sixty with a small n2o hit, but needs to hit it sooner (traction is there) because he is going 120+mph and this shows how the 60 effects ET.
Old 06-02-2005, 12:02 PM
00SS4780's Avatar
Off the line and more tire!
