How To Mount Bottle In Hatch Above Gas Tank?
Old 06-07-2005, 03:38 PM
SupahRich's Avatar
Default How To Mount Bottle In Hatch Above Gas Tank?
I removed the carpet to take a look at how much space I have between the body and the gas tank, and it doesn't look to be very much at all? What type/size of screws are you guys using to secure the brackets? (I'm using the regular NX brackets currently)
I've done a few searches but haven't been able to come up with any good info... I'm going to mount the bottle in the spare tire area but I would also like to have the ability to mount it in the hatch when I want to show off my setup
Old 06-08-2005, 05:02 AM
zrated's Avatar
I mounted mine in the hatch above the gas tank. I Took the four screws that came with the brackets and welded them onto the hatch under the carpet ( very carefully, the gas tank sits about 2 in below). Then poke the holes for the bolts to come through the carpet mount and done. Hope this Helps
Old 06-08-2005, 05:10 AM
ChrisLe's Avatar
Why drill through your deck and risk puncturing the tank? There's an easier way. Get yourself a piece of 1/2 inch plywood large enough to use as a base to bolt your bottle onto. Mount your bottle on the plywood, then gorilla glue/epoxy it to the deck. You can then put your carpeting back on top. That way you don't drill through your deck and you have a nice neat appearance...
Old 06-08-2005, 09:40 AM
Robert56's Avatar
Gorilla Snot and ply wood here. The Vettes have the fuel tank/screw problem also.
Old 06-08-2005, 12:24 PM
Ravenous T\A's Avatar
Thats weird? I didnt have any problem mounting my 360 Bottle Heater bracket with the supplied bolts. I would just use some short self tapping screws, that way you can insure that your drill bit doesnt go into the gas tank.
Old 06-08-2005, 04:06 PM
SupahRich's Avatar
Thanks for the info guys... I was just wondering what methods people used to secure the brackets. I know of two guys personally that just screwed theirs to the body but both of them were '98's so I wasn't sure if tank clearances were any different between the plastic and steel ones.
The plyboard idea sounds like a good idea!
Old 06-10-2005, 02:02 AM
Hambone 7's Avatar
bingo. i bolted my nitrous works 10 pound bottle this way and it looks awesome sitting there under the hatchback glass.
Old 06-10-2005, 02:37 AM
SiL3NtXWS6's Avatar
I have mine above the gas tank, but i removed the gas tank when i drilled through. The gas tank would not fit back up with the supplied NX hardware so i cut the bolts flush with the nuts. Gas tank fit right back up. Do NOT drill without taking the tank out.
Old 06-10-2005, 03:41 AM
setxws6's Avatar
Thats clean, but I don't see any half inch of carpet sticking up from the plywood under the carpet. It looks like it was just bolted to the body?
Old 06-10-2005, 07:18 AM
N20LT4Bird's Avatar
Just drill through the tank; it will only leak when its full and you go around a turn......a little gas fumes never hurt anyone.
Old 06-10-2005, 07:37 AM
Nostang's Avatar
I drilled through mine with the gas tank in it. I just took it slow with a nice new bit and started with small bits and worked up to 1/2 drill bit. I used rivet rubber nuts to mount mine in this location. You can get these from McMaster-Carr for ~$8 for 5 of them. These slide into the holes that you drill and then compress and expand as you tighten the bolt in them. I have had mine in for ~3 years now and had no problems with them. Very easy to install and no dropping the tank. If you can drill 4 holes carefully and tighten a bolt then you are set. The part number is 93495A431 and their website is http://www.mcmaster.com/ .
Matt
Old 06-10-2005, 10:43 AM
Robert56's Avatar
That's because on the Z06 the carpet has foam backing about 1/2 thick, so when pulling tight it evens out and looks flush.
Old 06-10-2005, 11:33 AM
LS69TA's Avatar
I removed the child seat anchor on the pass. side and bolted it there and just angled the bottle towards the drivers side. It ended up being at roughly a 45 degree angle. Re-used the torx head bolt as well.
Old 06-10-2005, 08:57 PM
Gold Z's Avatar
WE moved the carpeting back and used a small welder to weld four bolts to the floor with their threaded ends sticking up. We then cut a small X in the carpet where the bolts were trying to come through the carpet. Then we just placed the mount on the bolts and tightened the bolts up.
Old 06-11-2005, 01:17 AM
Robert56's Avatar
Where'd you get the bottle blanket from, nice.
Old 06-13-2005, 09:35 AM
blacktransam's Avatar
i did mine like gold z
Old 06-13-2005, 10:22 AM
150shotWS6's Avatar
I like mine in the back seat area! Saves money from buying a Opener!
Old 06-13-2005, 04:59 PM
Gold Z's Avatar
Robert56, I had it custom made at the same upholstry shop that upholstered the rollcage. It has a 1/2" layer of dense foam padding wrapped around the bottle.
Quick Reply: How To Mount Bottle In Hatch Above Gas Tank?
