Changed from 75 shot jets to 100......now nothing!
I got my NOS 5177 system up and running with the 75 shot jets installed.....worked great.
So.....last night I figure it's time to up it to the 100 shot jets. I perform the simple jet swap.....and leave it overnight.
Today on my way into work I try it......and NOTHING!
I haven't had time to troubleshoot it other than to check the purge (yep....there's nitrous) and verify the WOT switch under the pedal is working (at least I can hear it click at WOT). And the light on the master power switch comes on.....so there's power.
Obviously I'll check into it more in detail tonight when I get home......but I was just wondering if anyone has ever experienced anything like this???
I find it hard to believe that changing the jets has anything to do with this.....but it was literally working one moment (75 shot) and not the next (100 shot).......
Also......I'm a little concerned with the way the nozzles point away from the MAF in the Vararam.....can anybody verify that's ok?
Sorry for the dumb question......but I'm a
Car is '99 vette.....window switch is NOT installed YET. Pretty basic NOS 5177 install......
You mean something like this, first pic is my current set-up, second pic is my first set-up. A buddy has his nozzles even farther away from maf but same place as mine (I have quads know he has duals). Dry nozzle locating is very forgiving. I would look at mech failure: noid, fuse, fpss, relay, wiring. Or maybe a clogged filter (screen in fitting on 5177). You sure bottle was open, as I have done that more than once.
Hey Robert.......I was hoping you would reply. I went by your pictures when I mounted my nozzles in my vararam.....
Here's what mine looks like......
And yeah......I'm sure my bottle was open......it was purging just fine.....and I shut it off when I got in to work. I'll check all the electrical when I get home tonight. I'm just a little bummed I didn't get to feel what a 100 shot feels like today........
Originally Posted by Robert56
My friend has his even a couple inches closer to the filter than yours and it works fine. He kocked off a base run 12.6 or 7, then a 11.48 with a 93rwhp hit.
What else does he have? I've got 4.10's and LT's to go with the vararam......I would think I might be close to that....maybe a little slower.....but same ballpark??????
I eventually want to bump it up to a 125 shot......but I need to get my injectors in and a tune first.
If it is purging then it is making it all the way up to the 2 noids. It would seem it is either your noid ground(s) or you relay fuse. Are you using a window switch.....if so check its ground to the micro switch and the chasis. Double check the position of the microswitch so that you know it is being tripped. I can feel mine through the gas pedal....but I drive a F-Body.....your vett is a survo controled TB correct?
