First Time Spraying...
Old 07-05-2005, 03:47 PM
99Ws6TransAm's Avatar
Default First Time Spraying...
Getting ready to hit my 99 with 68k miles on it..for the first time with a 125 NX wet shot. I have all the safety equipment i believe: 255 Walboro pump TR6 plugs, BMN window switch(first gear lock out) FPSS, Bottle Warmer, Fuel pressure gauge, WOT switch, Purge,Lingenfelter Aluminum Intake, Shark nozzle, Timing Trigger.
As good as i THINK i am...im still nervous as hell to hose it the first time. Everything sound right? Any suggestions/input for a first timer.
Old 07-05-2005, 03:53 PM
gollum's Avatar
Buy some octane booster.
Old 07-05-2005, 03:55 PM
1ScrudeDude's Avatar
Good luck man. I will have an identical set up as soon as I get $$ for the NX Gen II/safety stuff. I will also be going with a BMN 1st gear lock out.
I too think about what my 1st run will be like, hoping that I didn't fug something up that will make it go
Old 07-05-2005, 06:13 PM
Bad30th's Avatar
Jet it for 75hp to test it out on a shakedown run, then pop in the bigger jets once you're sure everything is A-OK.
Make sure you have plenty of open space and let her rip !
Good luck !
Bad30th
Old 07-05-2005, 08:55 PM
ws6sojuiced01's Avatar
Get some torco for the extra saft i was a little shaky the first time also.BUT SHE LOVES IT WHEN I SPRAY HER!!!
Old 07-06-2005, 12:46 AM
00RedWs6's Avatar
whats this first gear lockout thing with the window switch?
Old 07-06-2005, 02:06 AM
BNM window switch, give nitro dave a call he has them.
Old 07-06-2005, 07:25 AM
No spray in 1st. For people with 4.10s and no slicks..... like me.
