hard lining purge
hard lining purge
what will i need to hard line my purge. I just bought the master blaster purge from dynotune and want to hard line the lines. With a dual purge out of the windshield. I want to use copper tubing. What will I need to do this and what tools also where to get them. All and any help please
Cheapest place will be Harbor Freight. A bender and flare tool will run about $20 or less for both. Just get someextra tubing to do some trial runs. You may need to order flare fittings and nuts from Jegs or Summit, or get lucky and have a good local speed shop for that.
Good luck! It's actually fun bending the lines, you will see.
www.ksmetals.com sells a $2.67 tubing bender kit #321 (size range 1/16 to 3/16). The kit is designed for brass, aluminum, and copper, but harder materials can be bent by heating before bending. I found my K&S tube bender kit at Hobby Lobby.
Most all hardware and hobby stores have K&S metals on display. Your plastic lines and fittings can be found at most any auto parts store.
Originally Posted by charlie c5
Actually you should go to your local Hi-Lo or Autozone and get 1/8" brake line, I use it and it works great. It bends easy and is very inexpensive. You can use the fittings that come on the line with your solinoids, they are 1/8" npt
You can go to Oreilly auto parts...
Autometer Makes hard copper tubing that you can bend with your hands....
There about 12 dollars a peice.....
2 of them will get yo ua hard lined dual purge...
You can always go to Home Depot and see what they have for brass tubing in the plumbing section. I used 1/8" from there along with a 90* elbow with a compresion fitting. I just bent mine by hand and then painted it but you should be able to get a small tube bender cheap at any autoparts stores.
You may be actually waisting nitrous with 1/4." You can get the same or even better purge plume with a 1/8" tubing, just by flaring the end. And, yes brass will work, but I have been dealing with nitrous installs for more then 13 years, and I've learned a few tricks to the trade, and I've seen too many purge systems with brass tubing run into trouble. Brass though inexpensive is very soft metel, and that means it will bend and kink very easily... Butu, that's my suggestion, and it's whatever works for you.. Just have fun what ever you do..
What is the advantage of hard lining the Purge? Is it just to make the set up be more permanent and last longer? Does it have any effect on the actualy purge size?
I might hard line mine as well???????????
