finally got my nitrous working...
after i bypassed the stupid ramchargers timing tuner do they like not test these units or something?? im gonna have to go up to ramchargers to get a new unit or something but whos to say the new one will work or that they will even exchange it.
anyway, without any timing change, no window switch, fpss disabled and hitting the nitrous still does a minor popping out of the exhaust but hauls butt. its not as much of a kick in the butt as i expected, but im only on the 75 shot. anyone know what the popping/minor backfiring could be? i dont know if its detonation or what, im bad at knowing which sounds are what, just sounds like popping out of the exhaust a couple times through the wot run. also, without a window switch for now, is it alright for me to shift through the gears? i was just testing it in one gear. oh and uhh its definately hitting pretty darn good, my clutch pedal got soft afterwards. also, right after i pulled the bottle from inside my house and hooked it up, my bottle pressure was 1200psi. i cant read my guage when the bottle is in place as it is broken and leaked out most of its fluid which makes it only possible to read when the guage is upright.
to mch fuel I would guess....try this...
during the nitrous run, keep the throttle floored, and then switch the nitrous system off while still at full throttle, and THEN let off the gas pedal. I bet that will solve your popping sound (at least at the end of the run).
If it is popping during the run, maybe a little too much bottle pressure??? Are you using the TR6 plugs gapped at .038?
SDB
SDB
SDB
SDB
im on a stock fuel pump, pushing 350rwhp on a mustang dyno, would the stock pump cause this?
probably a lean pop from too high of bottle pressure...pull some plugs and carefully inspect them. I bet they are very white. Fuel pump should be OK....always a good idea to get Walboro 340 pump though, especially on the bottle.
SDB
SDB
welp, last night it did the same thing as when i had the timing tuner on. im leaning towards something with the bottle pressure, or maybe my nos filter is clogged or something with the wiring. this sucks, almost makes me want to just sell all this crap...
ok im really leaning toward a bad solenoid or not enough bottle pressure. it ran a lot better today. i took a pic of my plugs, they have like 500miles on them.
Give me a call at 586 790 4406 about the Timing Tuner. All units are bench tested before they ship to Ramchargers or anyone else. I will be happy to help you fix your problem or test the unit if need be.
Mike Licht
Mike Licht
Mike Licht
Mike Licht
