Dry shot a/f ratio
Old 08-03-2005, 07:56 AM
Sport Side's Avatar
Default Dry shot a/f ratio
How can you keep your n/a air to fuel ratio legit, while having your air to fuel ratio much richer for a dry shot? How do you correct the injectors to inject the proper fueling while spraying?
To make an example lets say:
5.7L n/a
13.0:1 AFR
-100 shot
12.0:1 AFR (target)
How do you reach the target while maintaning the 13.0:1 AFR all motor?'
Thanks.
Old 08-03-2005, 11:58 AM
Sport Side's Avatar
Anything you guys have learned to do with your tune? I'm trying to fall inbetween the above example. Keeping a decent n/a air fuel ratio but also, having that tad bit fatter air fuel ratio for the spray. This is thru the maf so I figured there has got to be a way to do this with a tune. I have HP Tuners so if you could give me a few ideas, I'd appreciate that. Thanks.
Old 08-03-2005, 12:16 PM
Robert56's Avatar
Use your fuel adder vs IAT. If you log both you'll see temps go lower on the spray. What this will do is add an additional multiplier on top of your wot PE multiplier only on the spray. I am really time limited but that's the basics of the two tunes in one concerning fuel ratio. Ther are a couple more things that can be done using this extra multiplier, and I'll try to get back to ya later. The year of your vehicle may not support this additional multiplier? It comes zeroed out in HPT.
Robert
Old 08-03-2005, 02:17 PM
Sport Side's Avatar
After reading what you wrote earlier, I went snooping around in my HPT .bin file and noticed exactly what you just mentioned. The fuel adder vs. IAT is unusable. Thanks.
Old 08-04-2005, 12:32 AM
Robert56's Avatar
There's still a couple ways to do it. I just got back from the track using one of them and a 11.73 with a 50 shot and mild launch on new clutch, so it works. Will explain in the morning.
Robert
Old 08-04-2005, 08:08 AM
Sport Side's Avatar
Thank you Robert.
Old 08-05-2005, 01:26 AM
Robert56's Avatar
Haven't forgot, been busy. Will still get to you.
Robert
Old 08-07-2005, 06:16 PM
Robert56's Avatar
Sorry sportside, it'll get a little involved. I am setting up my bike for the drags and keeping car ready. If this is holding you up in any way, say so, and I will get right to it. Sorry for the delay. Or, I could just high light things and go from there? I am backed up on E-mail/PM questions also.
Robert
Old 08-07-2005, 06:21 PM
Sport Side's Avatar
Take your time.
Thanks.
