Dedicated Fuel system SPECIAL!!!!!!
Old 08-10-2005, 01:51 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Dedicated Fuel system SPECIAL!!!!!!
Ok guys we are offering 50.00 off of our F-Body Non battery relocate dedicated fuel system.This system come complete with a custom built cell that mounts by the fuse box area,Walboro 340 Intank pump,Aeromotive Regulater(will flow high or low pressure),all fittings and hoses.
This system normally sells for 699.00.For the month of August it is 649.00
Here is a link to all the ones we offer.
http://www.nitrousoutlet.com/outlet/...section_id=122
PICTURE COMING SOON......
Thanks
Dave
Old 08-10-2005, 02:16 PM
TINKRD's Avatar
this might be a dumb question. But what are the benefits of a dedicated fuel system and low press vs. high press?
Old 08-10-2005, 02:33 PM
XJOSHX's Avatar
With a dedicated fuel system you can run regular pump gas in your gas tank and still a big shot. In the little tank just run some race gas. High pressure is for fuel injection, and low pressure is for carbs.
Thats what I have learned anyways.
Old 08-10-2005, 02:48 PM
LC
LC's Avatar
damn i want one of those so much.. and i dont have Nitrous!
yet.. at least..
Old 08-12-2005, 09:10 AM
yet.. at least..
Well we can change that real quick.LOL
Dave
Old 08-12-2005, 10:14 AM
TINKRD's Avatar
I'm going to the track next weekend. Would it be beneficial to put 2-3 gallons of race gas in the tank for the juice? I've read that it doesnt really help you if you're running NA,but have never heard anything for the spray.
Old 08-12-2005, 11:47 AM
383LQ4SS's Avatar
Jaypee....do a search on race gas an nitrous. There is alot of info out there. Or if you dont find what you want start a new thread on race gas on motor vs nitrous. Try to keep this thread about Daves badass fuel cells
I wish I didnt already have my ugly *** Jazz setup or I would have bought one of these. Makes it so damn easy and looks great.
Old 08-12-2005, 02:52 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Oh grrrrrrrrr...I don't have a nitrous kit yet, but as soon as my wheels sell, I'll probably buy this since this deal is so good, and it is such a nice looking piece.
Old 08-12-2005, 02:57 PM
MeentSS02's Avatar
Oh, but I do have a tech question about this system...I'm guessing you can change the fuel pressure on this to alter your AFR when you are spraying. Now, since I have HPTuners and a Wideband, I can also tune my car to reach the desired AFR. So is it better to adjust the stand alone system to get the desired AFR, and have a tune that backs down the timing, OR just have a tune that backs down timing AND adds fuel (though the injectors)?
Old 08-15-2005, 04:16 PM
Ok,
This system is just for the nitrous side.You will adjust you NA air fuel through your computer.You will adjuts your airfuel on nitrous through changing the fuel jets in the nozzle.If you need a small adjustment you can do it with fuel pressure.
Dave
Old 08-15-2005, 04:45 PM
MeentSS02's Avatar
Dave, that's all I needed to know. So how much of an adjustment can you make with the fuel pressure alone? 0.5 AFR or so?
Old 08-15-2005, 04:53 PM
algws6's Avatar
Dave, where was this fuel system when i had my vette on the jug? it would have solved my problem that i have with the shitty gas that we have here.
Old 08-15-2005, 05:11 PM
Al,
We can always put you back on the juice.Have you seen NXs new vorvette maff systems.Its very nice.I know you liked the maff kit we put on the TA so I know you will love this one.
Dave
Old 08-15-2005, 05:13 PM
I like to say making your changes for small changes are ok for using the fuel pressure.If you need big changes.LIke you did a pull and your air fuel was high 10s or so I would do a jet change.
Dave
Old 08-17-2005, 08:59 AM
To the top
Old 08-17-2005, 11:54 AM
White98Z's Avatar
Ok how big is the pump and what is the max shot you can run with one of these?
The pump is a walboro 340.
At 10 PSI you can run upto a 1200 HP shot.
At 45 PSI you can run up to a 900 HP shot.
Dave
Old 08-17-2005, 02:07 PM
WS6snake-eater's Avatar
Pics?
Old 08-17-2005, 03:47 PM
Ill have them shortly.I have missed place our pictures off the camera somewhere.
Dave
Old 08-25-2005, 10:34 AM
To the top
