Critique my nitrous progress....
Old 10-03-2005, 12:51 PM
7 Second Club
Phil99vette's Avatar
Default Critique my nitrous progress....
Here's a couple of things...
1) The rails are going to be stripped and we're going to weld aluminum tabs to allow it to bolt to the intake
2) After the rails are welded, we're going to powdercoat them either mirror or gloss black
3) The fuel end needs to be cut down
4) The fuel solenoid is going(reference in pic 1) direct below the Fast logo with a straight pipe coming out and 90 back to the rear of the car into a 45 and than into the rails.
Direct Port 1
Direct Port 2
Old 10-03-2005, 01:02 PM
7 Second Club
Also, who makes a 1/4" tubing bender for tight bends?
Old 10-03-2005, 01:19 PM
J&J Speed Shop's Avatar
I am sure the wife isn't happy with the nitrous setup on the kitchen table!
Looks good, I have a bender from either SnapOn or Mac that does pretty nice bends with 1/4", how tight of a radius are you trying to get? I have filled tubes with sand before and capped both ends, then bent it around a rachet handle
Old 10-03-2005, 02:57 PM
Z284U2TRY's Avatar
thats a good idea. I just used everything around to bend with. I tried to find a bender that would get close tight turns but didn't find one out there. a vice is a good thing to have to hold the pipe while you make your bends.
Old 10-03-2005, 03:28 PM
sleepersilverado's Avatar
so far so good. you should be able to find a brake line bender at the parts store. they have some that do multiple sizes.
Old 10-03-2005, 03:41 PM
7 Second Club
I want to tighten up the rear bends, they fit but way too big. I purchased a bender from autozone but its like a 1" radius or so, I need like 1/2".
Phil
Old 10-03-2005, 04:39 PM
Robert56's Avatar
Phil
I haven't seen one with a 1/2 radius. If I need it tight like that I just find somthing small to bend around. I am mostly using SS so it can take a pretty tight radius without crinkles. Some of my custom jobs I do 1000s of bends (big boats).
Robert
Old 10-03-2005, 07:08 PM
BadAssFast's Avatar
Excellent. That would never fly in my kitchen!!
Old 10-04-2005, 11:36 PM
7 Second Club
We redid the rear lines and are much happier with the way it is setup now. Where can you get the line locally? Would a brake shop have the line? We're going to start on the fuel side tomorrow than the fogger to rail connections.
Old 10-05-2005, 12:37 PM
7 Second Club
Anyone???
Old 10-05-2005, 01:31 PM
Robert56's Avatar
Industrial supply House
Robert
Old 10-05-2005, 04:07 PM
7 Second Club
Robert,
Do you have a link or #?
Phil
Old 10-05-2005, 05:35 PM
Robert56's Avatar
Phil I have a call into my guy that does all the ordering. But I believe places like McMaster Carr can fill the bill. But I'll get back when I recieve a call, he may have shut his phone off and went home, so maybe tomorrow.
Robert
Old 10-05-2005, 07:58 PM
gollum's Avatar
You can buy lots of neat NX stuff directly from here.http://www.shopatron.com/index/300.0
Old 10-06-2005, 12:36 PM
Robert56's Avatar
Phil, you can get what SS tubing you need at your local Hydraulics Supply House. I get mine out of the recycle bin at work.
Robert
Old 10-11-2005, 10:34 AM
7 Second Club
Short update...
I finally got some time to start working on the nozzle to rail connections. We had thought that they were going to be a PITA but after we made a little template for bending angles and where to start to get the desired finish angle makes it super easy.
Phil
