Spraying dry 50 and wet 150 together ok???
I have a Dyno Tune Dry kit right now and i'm thinking of converting it to wet.I'm wondering if it would be possible to spray 150 wet and 50 dry at the same time.Car is on stock fuel system,Hot Cam/918's,Headers.P&P Maf/throttle body lid Slowhawk Tune.Is this possible or not
Thanx BTLFEDSS
Thanx BTLFEDSS
I'm just running an intank Walbro but it's maxxed right now. I just got a hot wire kit and voltage blaster for it though. I would go with the Racetronix kit. My injectors where maxxed too with the dry shot but my cam is considerably larger than the hot cam. I think you will be fine but it won't hurt to check your pulse widths.
Originally Posted by MKS
GM muscle is doing the same but with a 150 TNT wet and a NOS 50 dry but he's using bigger injectors and a pump.
its always better and safer to use a fuel pump
1 Post
Originally Posted by BTLFEDSS
What kinda pump and waht about the injectors i believe they are 26.6's
BTLFEDSS
BTLFEDSS
I had A nos dry system and converted to nos wet 150 shot. I still have my dry stuff hooked up. I want to do the same, 150 wet and 50 dry. I already have wallbro pump,and 28.8 inj. I'll probobly upgrade my inj. My question is will I benefit from A dual stage or should I spray all at once??
