Spray & 3600 stall & 3.73's? Please Help
Old 11-11-2005, 06:58 PM
DevonsZ's Avatar
Default Spray & 3600 stall & 3.73's? Please Help
Would I have to shift into OD before the traps if I put in my 3.73's and added spray? Should I just sell the gears *still new in box* and just leave the 3.23's in the rear if I go with the spray? I was going to get the gears put in this coming monday but got to ride in a sprayed car today and was like . If I do both is there anyway to know about what rpm I would be turning at the line? Im thinking if I go with the juice i'd get a wet kit and stay around a 100 shot if that helps.
Old 11-11-2005, 07:20 PM
pman's Avatar
I am just at the top of 3rd with my setup. 3.73s,100 shot cam only A4. around 6700rpms.
Old 11-11-2005, 09:18 PM
DevonsZ's Avatar
Im still running stock valvetrain with the redline set at 6300rpm. So if your near the top of *6700* I guess it wont work?
Old 11-11-2005, 09:36 PM
BackinBlack02SS's Avatar
Depends on what you think your trap speed will be on the spray.
Old 11-11-2005, 09:39 PM
JodyJ's Avatar
It would also depend on what size tire you are going to run. I run a 28" tall tire with 4.10's, 3600 stall and a 100 shot and I cross the line at about 6200. I have yet to try the 150 shot.
Jody J.
Old 11-11-2005, 09:43 PM
DevonsZ's Avatar
On the motor I trap around 108.*not sure what a 100 shot would add* And for tires there around 26 inches.
Old 11-11-2005, 09:50 PM
Lets say the 100 shot adds 10mph to your trap speed, so you would be trapping around 118mph. With a 26" tire and 3.73 gears you should trap about 5700 rpm, assuming you have a m6. If you have an a4 you should allow for about a 5-10% slippage.
Old 11-11-2005, 09:56 PM
BADBOYZ28's Avatar
I run a 28" tire with a 4000 stall & 3.73's and so far have tried a 100 shot and was crossing around 6300-6500 or so in 3rd. So IMO no you wouldnt be in OD I dont think even with a 150 shot.
Old 11-11-2005, 10:13 PM
DevonsZ's Avatar
I redline at 6300 *stock valvetrain* Wouldnt I turn more rpm with the shorter tire BadBoyZ28?
Old 11-11-2005, 10:16 PM
DevonsZ's Avatar
So I should be ok then?
Thanks for the help guys im just trying to get this sorted out before the gears go in.
z28viperkiller's Avatar
I shift into od before the lights with 3800 stall and 150 dry @ 111 mph.
Old 11-11-2005, 10:40 PM
DevonsZ's Avatar
Thanks
Old 11-12-2005, 02:34 PM
ILL SUB's Avatar
I spray 150, with a 3600 stall, lgx3 Cam, stock heads and stock rear end, 3.23. I personally wouldn't go over a 3.42 gear if you are going to spray 150. And believe me, you will spray 150 eventually. It is to tempting
Old 11-12-2005, 04:30 PM
white2001s10's Avatar
No don't use the 3.73's. You'll go faster on the bottle with the 3.23 gears.
There is no question about this period.
Old 11-12-2005, 08:45 PM
DevonsZ's Avatar
Ok, and thanks for all the quick replys guys.
