To those with MSD RPM switches.
How many rpm before shift point should you set the switch to deactivate N2O???
MSD digital rpm switch.
A4 BTW,
Thanks
A4 BTW,
Thanks
Originally Posted by PREDATOR-Z
So basically 200 rpms shutoff before shiftpoint. Thanks.
If your running a stock tranny I would not spray through unless your planning a rebuild in the near future. My stocker is still doing just fine not spraying through.
Originally Posted by calongo_SS
If you're trying to keep your a4 alive you do.
FWIW I had mine at 6600, shifts at 6700. Then I bypassed that POS and dropped .4 sec from et and gained 4 mph.
Originally Posted by DD966
I don't understand why some guys want their nitrous turning on, shutting off, turning on, shutting off,... during a run. My shift light is set at 6000, N2O on is 3000 and off at 6200. Rev limiter is set at 6800. The most improtant thing is to make sure there is a safe distance between your turn off RPM and Rev limiter RPM. No problems so far... except traction , but 500+tq will do that on street tires. Actually its kinda fun going sideways shifting from 2nd - 3rd gear.
