Pics of custom NX DP installed
Old 11-17-2005, 09:27 PM
hugger427's Avatar
Default Pics of custom NX DP installed
http://community.webshots.com/photo/...06810925kYbWrX
http://community.webshots.com/photo/...06811314NIOokU
MCRacing did the all custom work/installation on the 4 solenoid 200 shot DP system (N20 solemnoids in back). Nitros Dave's fuel cell is a piece of art that's filled to the brim with C-18...great guys to work with!!!
I'll add pics of the complete install later...my camera died after a couple snaps...forgot to charge battery
Should have it on the dyno Monday I'll post those numbers too.
Currently 520 /520 RWHP/TQ NA
Old 11-17-2005, 09:46 PM
jerrad's Avatar
Looks awsome.
Old 11-18-2005, 09:25 AM
Nitro Dave's Nitrous Outlet's Avatar
Looks great... Nice colored car to..
Dave
Old 11-18-2005, 11:10 AM
BRIAN98Z28's Avatar
Cars goin to be a BEAST dude. Any details on the N/A setup??
Old 11-18-2005, 12:21 PM
hugger427's Avatar
thanks for the kind words.
The NA set up is a C5-R blocked 427, 244/244 615 112 lsa, ported 6.0 heads, custom Weisco coated pistons, Callies crank, pro billet rods, etc.
1-7/8 Kooks headers, TSP TD X-pipes dumped at the axle, FAST 90 intake and TB, 12 bolt Moser 3:73
Old 11-18-2005, 04:07 PM
Everything looks good but whats up with that return spring. I noticed you made a change to the outlet supply on the tank.What did you do?
Dave
Old 11-18-2005, 04:37 PM
BRIAN98Z28's Avatar
daaayuuum, thats a serious motor setup you got there. What crank and rods are you using?
Old 11-18-2005, 06:51 PM
hugger427's Avatar
Dave
Good eye Dave. That's what I call the F.A.S.T back up spring. I'm on my 3rd version of FAST's 90mm TB that's had idle issues....not tuning related and a known problem. This simple $2.00 spring fixed that problem and is a nice fail safe to the main spring.
Once I have more pics up you will see that Matt put an extenal filter on the system behind the cell and he needed to re-route the hose to make room...the filter is another fail safe to the internal sock filter.
BTW Dave, I really apprecite all your help on this project. Again, that cell is worth every penney...nicely done!!!
Old 11-18-2005, 06:54 PM
hugger427's Avatar
Thanks!
Callies 4" crank with Luniti pro billet rods.
Old 11-18-2005, 10:00 PM
SLowETz's Avatar
THAT is perty! Nice work!
Old 11-21-2005, 01:16 AM
Ok I see. Yes the pump also has a filter and there is also the sock. A extra filter will never hurt.LOL
Just make sure when they turned that fitting that it did not twist the fuel supply inside the tank shut.Nice work
Dave
