Dry Nitrous and tuning>>
I am currently running a dry kit and am running on the lean side on the dyno. In order to remedy this I need to add fuel obviously, but that will hurt my N/A tune. Is there any way around this??
depending upon how big a shot you're running,your fuel pump(if stock)might not be able to supply enough fuel and keep the required fuel pressure at the fuel rails and/or your injectors have reached their limits in their ability to supply the proper amount of fuel per cycle.
One simple option may be to simply move your nozzle a little closer to the MAF.
Another option is to richen up the load sections of your VE table... the one you will hit while on the bottle only.
A third option is to use a CTS tricker to add coolant enrichment while the nitrous is activated.
There are other ways still.
Robert
Originally Posted by highrevinhp
what kind of dry kit?
Can you raise the pressure on the regulator by changing the jet maybe?
Or even get an adjustable fuel regulator.
Robert
