Will it hold? The rear that is.
Old 11-29-2005, 08:58 PM
SSDriver's Avatar
Default Will it hold? The rear that is.
I currently have on order a Strange 12 bolt, 3.73's Eaton Super strength posi with 33 spline axles and a support cover. I want to launch at like 4k with a 150 shot of nitrous. Do you think the rear will hold up. Also what do you think the stock drive shaft/clutch will do. I have MT e/t street radials.
-William
Old 11-29-2005, 09:18 PM
227Hawk's Avatar
The weak point on a 12 bolt is the crush sleeve. If you replace that and keep them full of fluid they kick ***.
Old 11-29-2005, 09:49 PM
slowpoke96z28's Avatar
two words....
solid spacer.
other than that, a 12 bolt will be fine with a 150 shot
Old 11-29-2005, 10:07 PM
SSDriver's Avatar
Can you guys elaborate a little on the solid spacer. Where can I get one and any directions on putting it in? Thanks
Old 11-29-2005, 10:14 PM
227Hawk's Avatar
If you have an order ,in just ask them to replace the pinion chrush sleeve. With a 'chrome moly' tube mic'd to the same length. This will space the bearing and the yoke, w/o chrushing in.
Old 11-29-2005, 10:18 PM
iamsickofitall's Avatar
the stock clutch will most likely take a poo on you within a couple beatings
Old 12-04-2005, 05:24 PM
1badA3Z's Avatar
yea he is rite the stock clutch is history,go ahead and upgrade it,and as for the 12bolt it will be fine
Old 12-04-2005, 05:32 PM
SSDriver's Avatar
Ok thanks for the help. I just ordered a Textralia clutch yesterday so I should have no problems.
-William
