Dry Shot JET size??
Originally Posted by marine02ss
Hey I just tried it out with a 58 jet bottle at 900psi popping mid ti high rpm Could the bottle pressure do this??Race is tonight Felt awesome though
Robert
Its got hlt,3500stall,3.73,ls6 cam Nozzle is not facing the mass air is at the side of the lid spraying across He already left home Ill meet with him later fuel pressure is ok
Check every plug in the engine carefully. If everything seems right then you might have just one lean cylinder or a failing plug.
The popping normally means lean or a plug misfiring badly.
