Spray Happy
Spray Happy
Well I installed my DynoTune kit over the weekend.*not too bad to do* I changed my plugs today.*sucks* Then I went out and sprayed it. This has to be better than crack. In between the stall and the spray my street tires have no chance at all. Right now I have it jetted for the 75 shot but im sure I will jetting up soon.
i got to spray for the first time this weekend at the track, a friend let me drive his 408 stroker with a 200 shot, even though it was on street tires and i only got to spray in 3rd and 4th IT WAS A BLAST!!! im hooked!! ill be ordering juice as soon as the holidays are over.
Robert
LS1TECH Sponsor
Devon, I have not seen this. We have seen folks use braided rubber hose and clamp it over the blowdown tube outlet. If you looking for a much smaller line it might be tough to do. I once cut the blowdown tube and put a compression fitting on it to a braided line....That worked nice as i was able to use a bulkhead adaptor for a nice tight fit in the trunk...
Dan
Dan
Devon, NX part number 16093 will do exactly what you are looking for. It is a -8 female x -4 male fitting. This way you can put a -4 line on the blow off fitting and route it where ever you like. You can get this fitting from Nitro Dave or T Byrne Motorsports.
