Critique My new Nitrous Plan
Ok here goes, this is a cam only LT1(gm 847) with all the bolt ons, 2800 stall, 4.33's and dailey driver, will be getting a fresh forged short block before I hit it with all of this but want to set it up once and be done with it. The nitrous plan is as follows: 2 10lb bottles in the Spare tire well(will they fit?) both open and running a -4 line to a Y that will be -4,-4 in and -6 out running to the front. I have a wet kit with purge, purge is being converted to a dry shot. The -6 line will run to the front and be Y' ed out to two -4 lines, one to the dry solenoid and the other as short as possible to the wet kit noid. The dry shot will be set at 100hp and the wet at 200hp. I will be using a stand alone fuel system for the wet kit and a fuel pressure system increase style and spraying the dry behind the MAF. I am still running stock injectors, PCM and 255lph intake pump so I really don't think the pre MAF spray would work for me. I will also be using a FJO controller set as follows: Dry kit set on time to 100% as traction allows and then off when second gear hits, The wet stage will be set to start at 3k and shut off just before the shift, reaching 100% as traction allows. Both stages will be switch activated to 100%, so when in 3rd gear just hold the activation switch for the combined 300shot. For the street the wet kit would just be disabled and the dry kit on for the occasional street light. The reason for running both through a -6 line to the front is that I would still have a purge effect for the wet and a softer hit with hitting the dry out of the hole when Traction is at a premium and a hard shot would result in spin. Any input in appreciated before I call Dave and promise him my first born.
edited so it makes sence
For a 300 shot in a car around your weight I'd lower the rear ratio down to something between 3.0:1 and 3.3:1 if it was me.
Also depending on your converter, your 2800 stall may turn into a 4000 stall when you push the 300 shot, so keep that in mind you may have to swap it later.
I wouldn't run the big line from the back. I would run two smaller ones and not worry about the purge.
Anytime the nitrous sees an increase of area inside the line you lose some pressure and some cooling effect you won't be getting in the intake.
The bigger line also wastes a lot of nitrous that never makes it into the engine.
JMO
JMO
Ok thanks guys, so a single -4 line would be sufficent for my plans? I though I saw someone the other day say it petered out at 250. So should I have both bottles open and yed into the single line going forward or run 2 completeley seperate systems? I have 3.23 gears in it right now so if the 4.30's are to much I can alway switch back, my converter is really too tight for the way it sits now so if it flashed to 4k it would be right on the money. Thanks for the input guys
1) Those low of gears and spraying are a bad combination in my .02
2) I'm running a -4 to a 2 stage dry now, off 2 bottles. I'm getting ready to seperate
bottles to run my new D.P. off one. It'll make my install easier.
Hawk
Hawk
Originally Posted by Robert56
A single -4 line is reported to be good for a 400hp hit, something to keep in mind.
Robert
Robert
Originally Posted by ramairstyle00
i thought that was only when the line was straight? i know Mike at Cold Fusion said i should go with an AN-6 line..... or was he trying to sell me more goodies?
Thats what I was thinking,
why is it bad to spray with the 4.30's? I still have a stock rear and A4 with corvette servo and some other goodies along with tunning and it shifts like a dream, my goal is to have the 1st gear hit be soft enough not to hurt the drive train, once its rolling I'm not to worried. I was thinking the higher rear gears would take some of the strain off of the tranny. I cuurentley have the 3.23's in there so I guess I could try them and if I don't like it I could change them. Man I wish I had a 9 inch.
Robert
