FJO Mini Progressive controller
Old 01-14-2006, 10:55 AM
cyipher's Avatar
Default FJO Mini Progressive controller
Ok Ricky I got a new one for you...Rpm ramp based curve with first gear lock out. Is there any way to Keep the unit powered so it keeps track of gears so if your racing from a roll it doesnt wait a gear to arm?
Old 01-14-2006, 11:46 AM
Closed ex-Sponsor Account
NXRICKY's Avatar
hmmm, need to think about that gear lock out mode. since it relys on rpm drop and you must cross the high side before the drop is detected, hmmmmm. yes, turn the unit on hit it from a roll and go thru first gear and let the box see the rpm drop, then just cruise around with the system armed ready to strike. OR I like this better, set your single stage up with the same ramps in stage 1 and stage 2. using the trigger switch will allow you the switch between these two set ups ( with a little bit of wiring ). So then if you are out and about leave the control in the mode that does not have the gear loc out. then the box willonly be looking at rpm. sweet aint it. I can spec out the drawing for you, but can not post until sunday or monday. You can go ahead and wire it all up and have some fun the adjustment is simple and will take
you about 5min to do.
Ricky
Old 01-14-2006, 09:11 PM
cyipher's Avatar
No i just wanted to see if ic ould stump you...i dont have the unit yet but i will be ordering it soon.
Old 01-14-2006, 09:24 PM
ujslost2's Avatar
I have the controller and would like to see the drawing of the wiring. I would like to do this on my car. i would really appreciate it. thanks
Old 01-14-2006, 09:36 PM
SmaknaSS's Avatar
Cant you just uncheck the "Enable first gear lockout" check box in the FJO software?
Old 01-14-2006, 09:44 PM
spanktu's Avatar
you check that for one profile(first gear LO) and "trigger" the second one for a different profile
I guess the ? is can this be done on the fly?
Old 01-16-2006, 10:22 AM
NXRICKY's Avatar
Thats just wrong,
Here you go. Hope this helps.
Ricky
Old 01-16-2006, 03:16 PM
PAGregSS's Avatar
That is freaking sweet! I was wondering that same question. Once again, Ricky, you're the man.
Old 01-16-2006, 03:24 PM
ujslost2's Avatar
Yes that is a big help Ricky. I appreciate the diagram. The progressive controller is awesome too!
Old 01-16-2006, 03:46 PM
Robert56's Avatar
Your going to have to get up pretty early in the morning, to stump Ricky on wiring concerns.
Robert
Old 01-16-2006, 07:28 PM
ITSTOCK's Avatar
Can't Wait To Play With This Thing!
Old 01-18-2006, 05:54 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
Is FJO a sponsor here or who sells this unit?
Old 01-18-2006, 06:01 PM
ITSTOCK's Avatar
nitro daves nitrous outlet
Old 01-21-2006, 01:25 PM
red fury's Avatar
I purchased mine from Nitro Dave and will be installing it soon and will use NX Ricky's diagram above. Thanks for the great price Dave and thanks for the diagram Ricky!
