question about fogger
Old 01-15-2006, 10:20 PM
nosfedgta's Avatar
Default question about fogger
I have a question concerning a fogger. I have messed with all types of plate systems, single nozzle systems,, etc. My exp with foggers is limited. My question is this. How much of a difference would it be or how critical is solenoid location to a fogger. For instance. should the noids be connected to the dist blocks on a carb setup? or can you put the noids in a diff location and run a line from the noid to the dist block? I am having clearacne issues on a car tha I am working on so I though I would ask some questions before I move the noids....
Old 01-15-2006, 10:48 PM
white2001s10's Avatar
It will work either way.
It works better the closer to the block it's mounted.
Old 01-16-2006, 04:34 PM
nosfedgta's Avatar
ok, any other thoughts?
Old 01-16-2006, 08:28 PM
Robert56's Avatar
Like white said either way. Longer lines just mean a slightly longer time before power hits, a Tuning aid in my book. don't worry it'll work, and you can compansate for longer lines by having activation point a little lower. I do this often, a poor mans window switch.
Robert
Old 01-16-2006, 08:53 PM
bad6as's Avatar
is a fogger a purge?
Old 01-16-2006, 08:56 PM
ws6sojuiced01's Avatar
no its a nozzle
Old 01-16-2006, 08:57 PM
bad6as's Avatar
just a noob n20 queston, thanks
Old 01-16-2006, 09:02 PM
No problem buddy.
