i wanna spray 78,000 miles
i wanna spray my car it has 78000 miles i was thinking about the new wet plate by NOS. do you guys think its safe. i wanna do a 100 shot.
Originally Posted by dameter21
i wanna spray 78000 miles
I am too new to chime in from expierence, but I am betting most will give ya a hearty I am installing my first kit on with 45,000 miles on the motor.
my car is a 2001 ss ,m6, slp longtubes, high flow cats, borla catback, lid.
You can run a 100 shot all day long and never hurt anything its when you spray 150 everyday is when the clutch will take a dump .
Originally Posted by =ZoomZ=
Only real issue you might have would be clutch .
Are you sure??
Last time i checked is wet is rated @ a minimum 50 lbs on fuel.
Tht's a pretty low rating, but somebody with 78,000 is good to go?
If the pump is low on pressure you will go lean
Hawk
what do you guys think about the zex, and the cold fusiion kit, do they make the power like tnt and nx has shown us.
system. It will throw some numbers down. If starting out new, my .02
is run a dry shot it will work GREAT for you.
Hawk
from what ive read sprayin will be fine, just be sure to get some saftey things such as a WOT switch and a window switch. Also most people will reccomend a new fuel pump, some say its not needed, but id strongly reccomend you get one. Cant be too safe....
Robert
I put my kit on at around 40,000! I now have 75,000 miles and heve been through at least 25 bottles, not a single problem!
I have NX wet kit, 125 shot. I use MSD window switch, WOT switch, fuel pressure safety switch!
make sure to throw in a set of NGK TR6's and pull them out and regap them every 5000 miles or so and then replace them around 15k...well that's what I do for piece of mind!
