NOS Solenoid Frequency!?
11 & 7 Second Clubs
I just installed and was about to fire-up my FJO mini-controller when I noticed that I have to know the soleniod frequnecy for my NOS Cheater solenoids! How can I answer this question? Help?
11 & 7 Second Clubs
Many thanks, we owe you a beer! We just emailed Holley about this.
Now, the green LED light on the controller will not come on, but the red LED light does come on.
Closed ex-Sponsor Account
No green the tps setting is off a little, or the wire is not making connection. check the connections.
yellow led is stage 1.
You may have your multiplier off. If I remember correctly it's divide by 2.
Ricky
The yellow is also coming on. The problem is with the WOT switch. It seems that the controller is not recognizing it even after trying to adjust the controller, and there is a good connection. Any one else had this problem? Or should I just use the TPS?
Eric
Eric
11 & 7 Second Clubs
Eric,
We did not have the controller set to "The Trigger Switch will enable this Stage", which would seem to be the setting we need.
