Which one is the safety blow off adapter thing?
I want the thing that's circled in green for my NX bottle, so I'm pretty sure its #11709. When I clicked on the link for that part number it shows a rupture disc in the picture... does it in fact come with the disc? It's not in the description and I hate to buy extra parts before they're needed.
Thanks in advance!
Thanks in advance!
It should have come in a seperate little bag if it wasn't attached to the fitting. PM me your info and I'll have one sent out to you.
Matt
Matt
Originally Posted by code4
When I ordered my fitting from HSW it did not come with a new burst disk. You have to purchase it separately. I just reused the one that is already on the bottle.
Matt
Matt
Originally Posted by Nitro Dave's Nitrous Outlet
It is suggested not to reuse the old disk.
Dave
Dave
Got your PM, it'll be on it's way tomorrow.
Thanks,
Matt
Thanks,
Matt
Thanks, I just thought it had to be purchased separate. I ordered the fitting & blow down tube from you.
I learned something from Vinny @ 860 Performance when he filled my bottle (my first fill ), he asked how I put the rupture disc in and I had the right answer, I torqued it to the value that the instructions had (which was not very tight), Vinny told me it was common for people to just throw them on and to overtighten them, overtightening them makes them weaker and prone to be more easily blown out (before their rated pressure.).
Beer
Beer
Beer
Beer
Thanks.
I looked at my kit instructions and could not find it, I think it was on a seperate sheet that came with the bottle. I want to say it was like 15 nm but I am not sure (thats only like 3.3 ft/lbs). I remember that I was suprised at how little it was though. I am sure a call or PM to your favorite vendor would get the answer.
DynoTune bottle instructions:
BLOW-DOWN FITTING & BURST DISK INSTALLATION
The Purpose of this Safety device is to relieve the bottle pressure in excess of
3000PSI and vent it to the outside of a vehicle. Once the Disk ruptures the disk and fitting must be replaced. Always use care in using or installing devices used in high-pressure application. Caution Nitrous Oxide or CO2 can burn your skin! Always consult a professional before proceeding.
INSTALLATION:
1 ) Wash your hands thoroughly to remove all oils and grease before
starting.
2) Be certain your nitrous bottle is completely empty of all contents
before proceeding.
3) Remove the existing pressure relief fitting from your bottle. This is the
nut on the opposite side of the valve outlet.
4) Once the pressure relief fitting has been removed be sure the replaceable rupture disc (circular shiny disk) is also removed at this time. Caution: Never reuse a rupture disk! This Rupture disk must be replaced it every time the fitting is removed!
5) Check the new rupture disk and make sure its not damaged. Caution: Use no oil or lubrication on the fitting or disk during assembly and make sure you use only one disk. Install the fitting dry! Make sure and put the disk on the machine part of the fitting as shown. Thread it into the valve and hand-tighten making sure the disk does-not come off the fitting during assembly.
6) Torque the fitting to 15 foot-pounds. Failure to torque the fitting to exactly 15 foot-pounds could result in a catastrophic bottle failure and or severe personal injury! Do not over torque as this can lead to a failure as well! WARNING, do not use the bottle without a blow-down tube attached.
Here I used convert it for the Torque values
15 ft pounds=180 in pounds=20.33 NM
INSTALLATION:
starting.
before proceeding.
