N2O not working
N2O not working
I'm having a problem with my dry shot.
It's a .52 pill (100 app.) sprayed 7'' infront of the MAF.
Without the spray, everything is a-okay.
One thing to note is that I do not have a bottle warmer and the bottle was reading 800 psi.
When I hit the nitrous, the motor just sits there... Almost similar to a bog. I guess that would be the best way to explain it. The rpms just sit there and you can almost hear a strain.
The occurances are very random so I don't want to give any misleading information. On the street, I had a .34 pill (50 app.) set up and I nailed the gas in first and once the tach saw 4000 rpm I activated the nitrous... Seemed to have worked.
Hit the nitrous out of the hole at the track, and the bog similation occured.
Next pass, I nail it and then activate the nitrous after the converter flashes and the same bog-**** happens.
I'm kinda confused... and I know my information probably sucks but, I'm having a hard time describing what I don't understand.
Anyone had anything similar happen?
You want to get that bottle PSI up there to around 1000PSI in oder to get a good flow of liquid nitrous through the lines. 800 is a little too low and the nitrous may still be gaseous. Get the bottle warm and try it again, then at least you will have eliminated one potential problem.
Originally Posted by Robert56
It was working fine prior to this correct?
Robert
Robert
Yeah. It worked with the MAF before. Then, I did the SD tune and no problems.
Now with this new setup,all of a sudden....
Are you using the IAT for fuel enrichment?
Robert
Robert
Sooo, yes, fuel enrichment.
Originally Posted by BMN
Plugs???
Did you just re-flash the computer with the saved file from before or did you manually tweek the SD tune file and then flash it?
Matt
Matt
Did you add an additional fuel multiplier in your Power Adder vs IAT table? Sounds like maybe your not getting enrichment, and the 50 shot was small enough to be just lean, whereas, the 100 shot is way lean and it's stumbling?
Robert
Robert
If your DC is over 100% your injectors are static (wide open all the time). Could be a big part of the problem. If possible move up to a larger size.
Matt
Matt
Originally Posted by Sport Side
I don't understand why it would run lean with the MAF? Above 5500-rpm my injector duty cycle is above 100%, however.
Matt
Matt
But, yes... I do need some new injectors.
Is it possible that some of your SD tune is lingering in the tune you are now using? If not I would try relocating the IAT sensor back to it's stock location.
Matt
Matt
