Bottle has nitrous in it BUT!
okay so i made like 5 or 6 passes on the 100shot last night and then went to race a G35 coupe and there was no purge no nothing- went and checked the bottle everything was cool- close bottle up take line off then check to see if there is any nitrous- yes massive white cloud comes out- put line back on and turn bottle back on- still nothing...
anyone got any ideas? bottle was still @ 900psi
The bottle could be runing low. The psi may be at 900 with the bottle closed, but as soon as you hit it (or purge), it may be dropping down quite a bit if its almost empty.
Also, sometimes purging doesn't have teh big white cloud. It can come out completely clear.
My N2O won't hit when the bottle has anywhere less than 3 pounds left in it. Just one of those things. There is probably nothing wrong with yours, just refill your bottle and spray on.
Originally Posted by cartekls1
might want to specify where to check the filter!
NO since i didnt see any nitrous come out of the purge i did not spray because i didnt want to run to rich. I meant "no nothing" bye how much was comming out of the purge- i think i have leak in my guage port of the bottle- so i took it out and reconnected it with PLENTY of silicone sealant
