May Nitrous Specials..
OK for you school guys summer break is almost here. Its time to spend the day at your summer Job and your nights at the track. We have put together a few specials to help you shave some time of that quarter mile pass..
Group 1.
With the purchase of any Nitrous Express system with a 10lb bottle off our website recieve a FREE Nitrous Express bottle blanket. That is a 118.00 value..
Group 2.
With the purchase of any NOS Nitrous system with a 10lb bottle off our website recieve a free NOS bottle blanket for FREE. That is a 30.00 Value.
Group 3.
Our Custom plate system...
Your choice of stock, 90mm or LS2.
billet plate,o-ring gasket,throttle extention bracket,jetting from 50-200,10lb bottle with 45 valve,stainless steel quick release bottle brackets,300 hp lifetime warrenty solenoids with purge port desighn,all mounting hard ware,hoses and fittings..etc
NX automatic bottle heater,purge,fuel pressure safety switch,nitrous pressure gauge,NHRA valve and blow down tube.
Our Trick Digital Window switch with built in TPS and any gear lock out feature. (will controll 2 stages)
NGK TR6 Spark plugs...
Special price 1,075
Group 4
Our Famous Dual nozzle special..
THE DUAL NOZZLE SPECIAL.....
This system comes complete with.
1.10lb Bottle With NXs 45 degree Valve)
2.Dual Shark Nozzles
3.High Flow Ys(because Ts are restrictive)
4.Blow Down Tube and NHRA Blow Off Fitting.
5.Liquid Filled Nitrous Pressure Gauge.
6.Iceman Pure Flow Solenoids (LIFE TIME WARRENTY)
7.Jetting From 100 to 300 Horse Power.
8.All lines,Fittings,micro switch,wiring harness and relay etc.
To top this all off we are giving you a free replacement Bellow too put your dual nozzles in.The Shark Nozzles come with adapter nut fittings that will firmly fasten the nozzles to the bellows.The bellows has no holes in it.All you have to do is drill two small holes where you like them.Place the nozzles and go.
This system has the best of the best.No fitment issues!!!! No headaches to make it fit!!! This is one of the best deals we have put together..
This complete system is going for 599.99. With this system we GIVE you for FREE a new smooth bellows (50.00 Value)
IF YOU HAVE A CORVETTE OR LT1 AND DO NOT NEED THE BELLOWS.Subtract 50.00 for your price
Group 5
The 860 Deal
This package has the Custom -4 860 Heated Bottle bracket, F-body Spare tire bracket, and 180* or 90* Blow down tube.
This package is going for- 239.00
You can call in your order at 1-866-648-7637.
Thank you for your support.
Dave
Group 1.
Group 2.
Group 3.
Special price 1,075
Group 4
Group 5
The 860 Deal
Dave
Restricted User
+1 for a group v3.1 Plate system, minus bottle, feed line, heater, WOT Switch...you get the point. I think more ppl would convert to plate if they could click on a conversion price, plate, lines, noids for those going from dry or wanting to keep it Hmmmm Hmmm Anyway, nice deals as always Dave.
1 Post
I have a quazi Group 5 setup i'm seriously considerin the warmer bracket to add to the 860 mount plate...the blow down tube can be routed right into that little gromet in the bottom of the spare well...The bottle mount is killer. 860 makes GREAT stuff. Not to mention Dave's deals are awasome.
Dave, With the 90mm plate kit, how much would you charge for the hard lines when using your solenoid bracket for the pass. head from the noids to the plate?
Also, wanted to know if I could get the noids and fittings in a different color to look trick...maybe black for fuel and chrome/silver for fuel?
I also need a price on those fittings in anodized black that I talked to you about a few weeks ago for the fuel rail connection.
Thanks!
Dustin
Thanks!
Dustin
Originally Posted by Nitro Dave's Nitrous Outlet
Thanks guys for the feed back. I will keep the suggestions and see what goes down next month..
Dave
Dave
Im interested in direct port systems...i already have a plate system and wanting to do a dual stage with direct port...i was hoping for a direct port deal this month but i guess i'll have to wait
Thanks!
Dustin
Thanks!
Dustin
WE offer the parts to hardlien the system but not the hardlines already bent.
Pm me your number so I can give you a call in the morning about those fuel hoses. I lost your number and could not remmeber who I was talking to.
Dave
Dustin,
Dave
Dave
Work: 904-292-9440
Thanks for the help.
Dustin
Dave I just came across this thread, I just purchased the nitrous system with 15lbs bottle and purge today, I know it's not may but do you think I can get FREE Nitrous Express bottle blanket? I mean I only missed it by like 9 days Come on bud, hook up a fist time customer and make a customer for life
