no jets ok?
no jets ok?
I have small solonoids and even smaller jets. The solonoids can support up to 100 hp. It is a wet kit. This question may be off the wall, but what if I just took the jets out and let the solonoids go MAX? Would it not be the proper mixture with nitrous and fuel, or would this be ok? ..Sorry if this is a stupid question.
You won't be regulating the N2O & fuel for one. A/F could be very off and goes your motor. Upgrade your solenoids if need be to run a larger shot, a set of solenoids good to a 200 shot can be had for $70.
Matt
Matt
No it won't work with a wet system.
The restrictions will no longer be in the right proportion to each other, so you'd be relying on fuel pressure to control the AFR.
Yeah, it's a bad idea.
i tried it with my dry shot, and the lines with no jets didnt make a good seal, so when i sprayed there was alot of spray under the hood and around my airbox. So the same might happen with the wet shot, you definately dont want fuel being sprayed out under your hood...
