A little help please.
Ok so I just got my last part in the mail and I'm ready to have it all installed. I will have Pacesetter headers, TSP catted Y, Magnaflow Catback, and the NOS dry kit. Just a few quick questions: What plugs? Should I get a Window switch or is the WOT switch sufficient? Anything else I need? I plan on running a 75 shot to start. Thanks guys!
go with NGK-TR6 plugs gapped between .040-.038 for a 75 shot. and i would definetly go with a window switch if your a M6. even if you were a A4 i would still go with one. for another $50-100 its really worth it.
Restricted User
Sounds like someone knows their nitrous setup basics... Thanks Blk97WS6.
blue99SS- good thing you said start with 75...we all know your not going to stay there for too long. Make sure you get some logging done on the smaller shot to check things like the fuel system being able to keep up. GL
i get mine from NAPA...i know autozone doesn't carry them - if i'm ordering stuff from one of the sponsors, they usually sell them cheaper and i add a set to my order...it's not worth paying the shipping for plugs only tho
Restricted User
yep, NAPA for my plugs too. Checkers had them a few times, but not too often. Any WS should work...I hate the things, always see ppl having issues stemming from the WS or FPSS not being set right, so I dont even mess with them, but it is a good investment for starter and M6.
I just flipped through the directions and it says I don't need anything, that it will run on stock plugs and 92 octane. This has to be why you hear so many horror stories about nitrous. So NGK-TR6 plugs and a WS it is. Thanks for your help guys.
Restricted User
Well, it is half truth, it will run on stock plugs and pump gas....but for how long and its mos.def. not recommended. On the plugs, make sure the cap is screwed on tight, where the plug wires snaps on, those caps sometimes ship from NGK loose and can cause troubleshooting nightmares later. Use anti-seize on the threads, and dielectric grease on the porcelain, just a dab'l do ya. GL and have fun with it.
http://www.texas-speed.com/shop/item...id=29&catid=31
RPM pills? Plug one pill in for the bottom end at 3000 rpm when the spray activates and one for the top end at 6000 rpm when it turns off? Does the switch come with whatever ones you ask for? Thanks for helping out a newb and sorry about the 8 million questions.
The stocking number the stores will need on the plugs is 4177
I would suggest a Digital unit over the old analog style you have to have pills with.
WE sell the MSD for 95.00
http://www.nitrousoutlet.com/catalog...product_id=818
Or our custom digital unit with built in TPS and any gear lock out feature for 129.00
http://www.nitrousoutlet.com/catalog...product_id=964
We also stock the NGK TR6s.
http://www.nitrousoutlet.com/catalog...product_id=164
Texas speed should also be able to help with these.
Let me know if I can help.
Thanks
Dave
Thanks
Dave
http://www.nitrousoutlet.com/catalo...&product_id=818
Originally Posted by CAT3
Did you get a nitrous filter? Jet's? NHRA Blowoff valve fitting and blowdown tube?
Restricted User
Not vital, but if I had to skimp I'd get the filter before the blowdown. Both are very good items to have. Filter obviously keeps trash from clogging up a solenoid, open = very bad, luckily the 5177 has a backup noid. Blowdown tube and fitting keeps the Nitrous from clouding the interior in the event the pressure disc ruptures.
So to beat a dead horse,
NOS 5177 kit has:
FPSS
WOT switch
I just bought the WS
and will GET the Filter
anything else that is VITAL right now or can I slap this stuff on and try it out?
Thanks for all the help guys, its greatly appreciated!
NOS 5177 kit has:
FPSS
WOT switch
