Question after MSD Digital Window Switch Install?
Okay, got the switch wired up, noticed after I turn on my switch to activate my Zex Nitrous Control box, my rpm's jump up about 200, also the instructions say that the one cylinder setting is for the LS1's or 99 up Cobra's, well that did not work for me, I tryed all the settings and the number four cyclinder setting seems to be the one I want, ZEX came on and off at the settings I programmed. When switch is not on the on position, car Idles at the normal 900 to 1000. Did not find any writeups on this in the archives, hoping to get a good thread started here, for all future questions on this Window Switch. Thanx for input.
Anyone, I got some custom instructions from MSD, these ones have you running a relay. Well I got the Idle problem to go away, but the with this install from MSD, I can't get the Window switch to turn the Zex off and on at the set RPM. Anyone had this problem with this install?
1 Post
Check out this thread. This is how I wired mine up.
https://ls1tech.com/forums/showthrea...ght=zex+wiring
Good luck!
Mine works fine. I have mine set to 1 cylinder like it says. I have the wire form the window swich connected straight to the 2nd wire from the hot wire on the coil and it reads dead on the head.
