Opinions on best/fastest bottle heater
HSW, Dynotune, NX, NOS - whatcha think, why?
- how long does it take to heat up (starting psi to 1050psi) say a 15LB full bottle
- wattage
- blanket size (complete wrap around)
- auto shutoff / adjustable
- anything else you like
- wattage
The 300 watt heaters will heat the fastest, we all carry these. It depends on outside temp for lenght of time. My 15lb'er sometimes is like 45 minutes on a cold day, however, I have a 240 watt NX heater. I chose and choose to run the NX heater because of the lower amp draw, and I will have 2 heaters heating 2 15lb'ers. There is no 15lb full wrap around blanket that I know of, NX dose have the wrap around for the 10lb'ers. I like the Black blankets with the Nitrous Direct logo, which I have 2 of. And of course you should have an auto shut off. Most use the mechanical pressure transducer type sw. NOS uses the Thermastat typ sw. I run the thermastat currently and it heats bottle to a certain temp (mine 95*), whereas the mechanical type heat to a pressure. There are good and bad points to both, imo. But that is subjective. Hope this helps a bit.
Robert
Robert
if you have a chance throw the bottle under some hot water and it will be hot in under 5 mins. i do this while my car gets up to temp and use my heater to maintain pressure when im out and about.
Our Revolution bottle heater wraps 360 degrees around the bottle, so there is no "dead space". The Revolution is 280 watts too, so it won't drain the battery as fast as a 300 watter while your in the staging lanes. The kit comes with an adjustable pressure transducer along with weather tight electrical connections and weatherpack connections. There is some test data on our website, you can follow the link to the PDF file:
http://www.harrisspeedworks.com/shop...cat=269&page=1
Let me know if you have any other questions.
Thanks,
Matt
Thanks,
Matt
- wattage
- wattage
LS1TECH Sponsor
How long it takes varies depending on the starting pressure and the temp ouside. Wattage 300. But as we have found out not all 300 watt heaters perform the same. A lot has to do with the layout of the heating element wiring and shielding within the heater element itself.
Auto shutoff and adjustable.
Anything else we like - yes the price --- $99!!!!
But our customers are our best advertisment - here is a quote I noticed in the for sale section from Dame. Thank you Dame!
Dean
For the people that are on the fence about this warmer:
I bought this warmer 2 1/2 years ago when I got my first nitrous kit (used dry kit) worked GREAT... then I sold my dry kit and gave the kid everything.... I then bought a complete NIB NX MAF kit with NX warmer: I used it for ONE DAY!!! and proceeded to give it away, buy myself another one of these and have been happy ever since- you guys are lucky I paid the full price BOTH times! Might take a little time to adjust the thermostat to exactly where you want it ... but once ya get it- you'll be golden!
This really is the best warmer hands down (IMHO)
__________________
Damian
1999 T/A WS6 #0098 6spd loaded
blk w/taupe int.
Moser,NX,Spohn,BMR,Hal,2-step,etc.
Old H/C/I setup: 11.28@125 raceweight: 3920
New setup: 408 stroker Times:??? still in progress Clifford Advantguard 4 W/REMOTESTART
Dean
__________________
Damian
blk w/taupe int.
I personally think the 860 heated bottle bracket will give all the heaters a run for the money. Since the unit is made of alluminum it transfers the heat faster and stays hot.
Check it out.
http://www.nitrousoutlet.com/catalog...product_id=693
Dave
Check it out.
Dave
Closed ex-Sponsor Account
I will give everyone an idea and maybe someone will build it. Think of a 20lb bottle with the bottom cut off. Now slide a 10lb bottle inside. seal it on both ends. Fill with water get a hot water element for lets say 98' temp. And that will be the fasts most consistant bottle heater out there. Just remember to leave a little room for expansion on the heater water area...
Ricky
Ricky
That idea actually inspires me Ricky! But, I wouldn't want to buy a 20lb bottle just to cut it up. My engine coolant is 180°F, I think I'll run a line from my radiator into one of those "medical" hot water bottles or something. The water temp is so hot you would only need to cover a small portion of the bottle. The only problems are shutting it off once the bottle gets up to temp and keeping the hot feed & return lines from touching flammable/sensitive things.
Ricky
Ricky
I can see it now, bringing in my 10lb bottle to be filled up that weighs 85lbs when full.
Ricky
We can call it the Nitro Spa
Here is why I ask originally,
https://ls1tech.com/forums/nitrous-oxide/523943-nx-bottle-heater-will-not-heat-over-800psi.html
NXRICKY - any ideas?
https://ls1tech.com/forums/showthread.php?t=523943
Ricky
Well i have a both a nx auto heater and a cold fusion auto heater and the CF heats up way faster but why do you need it to heat fast?? (both are thermostat controlled)
Oterwise they both work the same. So I'd go for price myself.
I went with the 860 Bottle Bracket heater for about $100 bucks from Dave (NitrousOutlet) and let the Maximizer control the pressure and heater. I think the 860 is the best product out there and really heats up good after 15 min. It bought this unit so i would not have to hassle with a blanket when I get my bottle refilled. After 8 refilles it has been really nice convience and makes for a really clean install.
