PICS: my Nitrous Install---- 99% STEALTH =) ZEX Wet kit.... wheres the lines??
Why not leave the maf in place but have it bored out so it is straight through that way it looks like everything is still in place?
Other than that it looks good. I planned on doing something very similar actually.
Originally Posted by blacktransam
ok so you have a wet kit spraying through the maf??
If I understand you right, you're saying you're spraing a wet kit through the MAF? Just curious...why? I don't even know if that is possible or not, I've never seen a wet kit go through the maf. Wouldn't that cause problems?
Originally Posted by ninobrn99
the nx maf kit is a wetkit....it seems to be fine..why would he have problems?
Originally Posted by Turo
And it sprays through the maf? I always assumed it sprayed after the maf. Well, learn something new every day .
Only dry kits blow through the MAF. The NX kit sandwiches the MAF and the spray comes out of the rear portion toward the TB.
Originally Posted by Forteen3GT
bigger pics??? those are plenty big...
so... you chumps figure out where the line from the bottle runs??
*edit* nevermind that is the fuel line...hmmm...haven't found the bottle line yet.
some of you are clueless....I have a speed density tune, no maf. lol
you are right about the fuel line.... only those that know about wet kits can tell.
you guys remember that hose that runs on the driverside fender??
Originally Posted by udlose99ta
does it go up through ur air filter?
