Does Anyone know the NHRA rules about having a bottle in the cabin
Okay, here is the OFFICIAL rules for 2007:
2007 NHRA Rules - 12-27-2006
While it remains the responsibility of the racer to know the rules pertaining to his/her vehicle and class I would like to highlight some rules that will be enforced in the 2007 Season at Redding Drag Strip. It is important to note that there have been changes in the rules from 2006.
For Super Pro, Pro and Sportsman: (and/or street legal racers)
Super Pro ET: 7.00 to 11.99
Pro ET: 10.00 to 13.99
Sportsman ET: 12.00 to 19.99 (change from 06)
Section 1A – Nitrous Oxide: Nitrous Bottle(s) in driver compartment must be equipped with a relief valve and vented outside of driver’s compartment. Bottle must be stamped with a DOT-1800 pound rating and permanently mounted. (No hose clamps or Tie wraps)
Section 1A – Helmet: Drivers in all 13.99 or quicker cars and dune buggy-type vehicles running 14.00 or slower must wear a helmet meeting Snell K98, 2000, 2005 or SFI 31.1A, 31.2A, or 31.1/2005 Specs.
Section 1A – Protective Clothing: 10.00 to 13.99 all E.T. nitrous-equipped cars with an OEM or .024-inch steel firewall: Jacket meeting SFI Spec 3.2A/1 Mandatory.
- - All open body vehicles running 11.99 or quicker: Gloves meeting SFI Spec 3.3/1 and arm restraints mandatory
- - Dune Buggy 12.00 or slower: Jacket meeting SFI Spec 3.2A/1, gloves meeting SFI Spec 3.3/1, and arm restraints mandatory.
Section 1A – Driveline: Driveshaft loop required on all cars running 13.99 or quicker and utilizing slicks, except vehicles running 11.49 or slower equipped with street tires.
Section 1A – Master Cutoff: Mandatory on any car with a battery running 9.99 or quicker, any car exceeding 135 Mph or any car where the battery is relocated into the trunk area.
Section 1A – Transmission, Automatic: Spring-loaded, positive reverse lockout device and functional neutral safety switch mandatory. Transmission Shield meeting SFI Spec 4.1 is mandatory on any car running 10.99 or quicker; or any car exceeding 135 Mph.
Section 1A – Driver Credentials: Valid NHRA Competition License mandatory for cars running 9.99 or quicker. Valid state – or government issued driver’s license beyond a learner’s permit level mandatory for cars running 10.00 or slower.
Section 1A – Roll Bar: Roll Bar mandatory in all cars (including T-Tops) running 11.00 to 11.49, in convertibles running 11.00 to 13.49, and in all dune buggy type vehicles running 12.00 and slower.
Section 1A – Roll Cage: Roll Cage mandatory in cars running 10.99 or quicker or any car exceeding 135 Mph.
Section 1A – Hood: Optional. Carburetors must be covered by flash shield or scoop. Hood Scoop Permitted.
Section 1A – Rear End: Aftermarket axles and axle-retention device mandatory on any car running 10.99 or quicker, or any car with locked differential.
Guest
Posts: n/a
Originally Posted by blk04z
Is there any rules as to how the blow down tube exits? Can I use nitrous line as a blow down tube instead in the hard line in the kit?
if you are using a flexible line it must use a bulkhead fitting to secure the exit end
this prevent the line from whipping around in the case of a burst disc rupture
Summit has racing jackets for pretty cheap.
http://store.summitracing.com/partde...5&autoview=sku
Here is one of them
Here is one of them
6 & 8 Second Club
A decent track or racer will not race without the proper respect for himself & other drivers. A cockpit full of N2O blowing around will not be fun, or safe.
well crap. im gonna be *really* upset if i drive 2 hours this friday and i cant run my car.
got an idea.. throw my bottle in trunk of my friends car then install it after tech!
6 & 8 Second Club
The #1 jacket is ~$50-60. If you're in the game, you're going to pay to play.
I would do what you have to do, but a tip, don't waste a bunch of money buying the minimum safety equipment. I would never buy a #1 jacket, and I yell at my friends when they do. Buy the 9.99 stuff, it's better, safer and will last longer than the bare minimum stuff. A big item guys should all have, GLOVES. When I was on fire, you need your hands to get out and trust me, very cheap insurance. Good luck guys.
safety
if you wear a harness 5 pc, in your race car always make sure it is pulled tite in the shoulder straps. you don't want to be moving or leaning over to the side should something happen. you can lose control of the car,if you can't see where your going even for a second. pull them shoulder straps tight.......ask me how i know................RON
The following users liked this post:
Woodylyf767 (07-24-2022)
