How much hp will a nitrous tune/setup cost a NA motor
I havent documented it, but I would assume that it would make power levels go down because of the lack of timing. There is a reason that most motors like 26-28 degrees of timing. They make more power. If you only had 20 degrees on it power would be alot less. I would also like to see dyno graphs of it.
