nitrous hits slow??
Old 03-13-2008, 09:01 PM
dameter21's Avatar
Cool nitrous hits slow??
I've been spraying a 100 dry shot fine as of recently it seems to not hit instant like it used instead it comes into play like 2-3 seconds. And its activated by WOT switch. what could be problem..
Old 03-13-2008, 10:46 PM
2000Hawk's Avatar
Do you have a purge kit, maybe you got air trapped in the line thats why it doesn't have that initial hit. If you do, where is your bottle pressure at as well?
-Joel
Old 03-14-2008, 05:25 AM
BobDoLe's Avatar
what happens in that 2-3 seconds, does it hit hard after a 2-3 second pause, or is it just not hitting hard at all?
check for kinks in the line. are you using the spray bar by any chance?
Old 03-14-2008, 09:32 AM
Chris@NitroDaves
Guest
Posts: n/a
-Joel
What he said and How do you have your nozzle mounted?
-Chris
Old 03-14-2008, 05:46 PM
dameter21's Avatar
full bottle no kinks I zip tied the **** out of feed line,nozzle mounted on lid about 6 inches from maf pointing in the right direction on the inside, I'm stumped.
Old 03-14-2008, 09:15 PM
SlayerMaro's Avatar
You still didn't answer if you had a purge kit or not, though. That could be it.
Old 03-14-2008, 11:00 PM
dameter21's Avatar
no i don't have a purge.. isn't there a way you can manually purge the line i heard that somewhere, I've always had purges kits except this car.
Old 03-15-2008, 12:31 AM
MeanWS6's Avatar
purge kit = problem solved
