Nitrous Outlet Kit LT1 Plate Kit Install Completed!
I know this is a repost from the LT1 section, but Dave asked me to post this here in the nitrous section as well. This install was just finished up last weekend and I don't have any runs yet. Planning on a 150 shot and will hopefully see some 10s out of it.
Nitrous Outlet LT1 Plate Kit
Solenoids (Nitrous - Purge - Fuel)
View from driver side
Another view from driver side. Shows hard-line from fuel rail to fuel solenoid.
Nitrous Outlet Ashtray 4-Switch Panel
Nitrous Outlet Ashtray 4-Switch Panel (Armed)
Nitrous Outlet Single Stage Window Switch/WOT Switch
Nitrous Outlet Single Stage Window Switch/WOT Switch (Armed)
MSD Digital 6 Plus, Pulls 4 deg. of timing when system is armed
Nitrous Outlet 10 lbs Bottle, 860 F-body Mount, 860 Heated Bottle Bracket
Bottle showing heater pressure switch, pressure gauge and weather pack connectors
Transparent view of bottle behind interior panel
Hidden bottle in spare tire area
Autometer Digital Pro Shift Light
Autometer Digital Pro Shift Light, illuminated blue
Mine too. So you got them all pre-bent and they fit out of the box? Or are you local and they took care of it at the shop? I might really consider this if I can buy pre-bent lines that can be shipped to me.
Very nice install. Man it's tight under the F-body hoods !! Your strut brace makes the perfect "frame" for your solenoids. Sets them off well.
I look forward to seeing your results.
Later,
Brad
Later,
Brad
Dave had a LT1 intake and fuel rails at the shop and pre-bent them for me. I am only an hour away but they made the lines without the car being there. I would say call Dave and see what he can do for you.
What strut tower bar is that? Dave recommended that I use the fuel rail mount like you did, but I have the Edelbrock STB. I think I have to check to make sure I have clearance, I think the edelbrock piece comes in more at a angle, I don't think its curved back to the cowl.
Nice install, I'll be happy if mine comes out looking half as good.
Here's a vid from the first dyno session. The shot worked out to be right around 125 HP.
http://www.youtube.com/watch?v=z_DL_CkJXlw
I've got a Nitrous Outlet dedicated setup being installed right now and I'll probably step up to a 200 shot. I'll try to post an update when it's all finished.
