HSW dry plate kit with interface
well i just bought the dry plate kit. still trying to figure out what i want to get as far as the extras, injectors, purge, bottle heater, gauges and controler. i want to get what i need but dont want to get what i dont need.
im still trying to decide on the nitrous controler. i know i want the wot switch and window switch in one, im just gonna be a single stage maby i should give hsw a call and get there insight
I didn't get a purge kit for mine. It will only effect the first pass, or if you are worried about it just when doing your burnout hit WOT(to activate the juice) for a split second and "purge" the line.
And when you are doing racing just carry a wrench around with you and loosen the line from the bottle just a little bit and let it leak out.
Saved money! No need for a purge kit!
Definitely get a bottle heater. I bought the DynoTune/Nitrous Outlet digital window switch. But that was before HSW came out with the MicroEdge which is really nice.
