Is there such a device or product?
Old 08-15-2008, 08:06 AM
Joinedthedarkside's Avatar
Default Is there such a device or product?
want to know if there is a product that has a lean shut down and is also a timing tuner in one? I have seen lean shut down with window switch and timing tuner with window switch but i already have a window switch and want to know if i am gonna have to buy both products and use all three or sell mine and just use the two new products or if there is one that has both or even all 3 in one.
Old 08-15-2008, 06:28 PM
guess thats a NO!!!
Old 08-15-2008, 06:45 PM
Hell-Bent SS 2's Avatar
look at harris speed works they just released a new product called microEdge nitrous controller.They are a sponser ----->
Old 08-15-2008, 07:14 PM
yeah i seen that and it looks like a nice piece but once again it only does one of the two things i want since i already have a window switch i just need a lean switch and a timing tuner
Old 08-15-2008, 07:37 PM
fstphx's Avatar
how much timing do you need? its a simple circuit to trick the IAT
Old 08-16-2008, 06:52 AM
only 4 or 6 degrees
Old 08-18-2008, 03:14 AM
ttt anyone?
Old 08-18-2008, 04:44 PM
Midnight02's Avatar
I'll gladly bump this because I'm trying to find the exact same thing!
Old 08-18-2008, 05:20 PM
SuperSlow02's Avatar
they are suppose to release a Edge 2, suppose to be their joined with their interface...so it will adjust fueling, pull timing, window switch...yada yada yada
Old 08-19-2008, 07:06 AM
as long as it would also have the lean cut off thing i would be all over it
Old 08-19-2008, 10:13 AM
fstphx's Avatar
If its couple with the interface it may still only pull 3 degrees-
The interface tricks the iat
Old 08-22-2008, 07:08 AM
hmmm not enough
Old 08-22-2008, 06:02 PM
It will pull more but you have to alter stuff via tuner...
Old 08-23-2008, 07:07 AM
damn i thought this domestic thing was supposed to be easier and better, maybe i will just throw the kit on my rx7
Old 08-23-2008, 12:18 PM
Thats why you just pull timing with HPTuners...Unless your motor is built, your not going to notice any different
The orginal narrowband tune on my car netted me 7.95s at 88mph
The wideband Nitrous tune which we pulled a few degrees netted me 7.91s at 90mph
so pulling timing isnt as bad as some people think, usually just depends on what the engine likes..
