Northwest Members WA, OR, ID, MT, WY, SD, ND
So what should i start saving for? Suggestions plz
Old 09-28-2010, 10:45 PM
chapmansZ28's Avatar
Default So what should i start saving for? Suggestions plz
Ok as you can tell what i have done to my car so far... Idk wat to do next, rear end, suspension, tranny, engine work, if so what should be the next thing. Please help all details and suggestions welcome... Im a newbie so i can take the hints and help... :-D... I would like to hear all the recommendations from all members
Old 09-28-2010, 11:05 PM
*02WS6TURK*'s Avatar
GM 3.73 Gears work well in a A4. Nice change over the 3.23's. What suspension work do you have done at this point? If your stock 10 bolt is holding up, then I wouldn't mess with it nor waste the $$$ on another. Nitrous is always a route you could go to if you are wanting to go faster.
Old 09-28-2010, 11:09 PM
Suspension wise I would recommend
Strano hollow sway bars
UMI SFC's
UMI Torque Arm
UMI Adjustable Panhard Bar
UMI control arms
Koni or KYB AGX Shocks
Old 09-28-2010, 11:50 PM
Well i got the kyb shocks already and ya the rear end is fine so far. So you think 3.73's will b a good up grade? I know i got a good amount of power in my car now but i always wanna go faster but i wanna b able to put it to the ground, and i could deff use suspension upgrades. What nitrous system should i look into and what size shot? Any more suggestions?
Old 09-28-2010, 11:55 PM
Oh just remembered i believe it has 3.43 gears in it now(i might b wrong but there not the stock gears) still suggest 3.73's?
Old 09-29-2010, 12:17 AM
zlicious94's Avatar
Umi and strano suspension ftw!
Old 09-29-2010, 12:27 AM
ls1whip's Avatar
you have a pretty sick engine built up brah, id focus on handling and getting that power to the ground. 3:73's or 4:10's would wake up your car even more just gotta get a speedo calibration like you prolly know. cool car btw!
Old 09-29-2010, 12:38 AM
99FormulaM6r's Avatar
From what I've read it's not really worth swapping from 3.23's (or 3.42's if you have them) to 3.73's in most cases. You're going to see more gains elsewhere IMO. Try checking out the suspension section for some good ideas.
Old 09-29-2010, 01:06 AM
Alot of good advice keep it coming please and ill need to check up on the gears stuff... And ill look into suspension prolly gonna cost a pretty penny to get all that fun stuff tho... Well most everything is gonna cost me a lil now that i have the basics done
Old 09-29-2010, 08:25 AM
Nitroused383's Avatar
What exactly are you wanting to do with your car? Auto x, handling, traction, launching hard, drag racing what?
Old 09-29-2010, 09:59 AM
Mikey 97Z M6's Avatar
That's what I was going ask.
To the OP, we need to know what your intentions are with the car before making a good recomendation on parts. Has your trans been rebuilt? If not, I'd start saving for that. Those stock 4L60e's don't seem to last long with high stalls. Are you running an aftermarket trans cooler?
Mike
Old 09-29-2010, 10:27 AM
zlicious94's Avatar
Procharger, 9" rear, and cage!$!$
Old 09-29-2010, 10:29 AM
smokinponcho73's Avatar
Yeah I am with Mike I would save for a tranny rebuild and then a rear after that everything else will seem cheap.
Old 09-29-2010, 11:05 AM
I've gone from 3.23's to a 3.73 and it was a night and day difference. Some 3.73's would really wake his car up. Now if you have 3.42's I wouldn't waste the time.
Old 09-29-2010, 11:44 AM
I do have the 3.42's in my car currently so im not gonna waste the time, tranny is stock and never been touched at all... And my intentions overall are... Street car that can run 10's... That is my overall goal. And thanks for all the help everybody, all recommendations are welcome
Old 09-29-2010, 12:06 PM
Then I wouldn't waste the time on 3.73 because the gains would be minimal.
Like Mikey mentioned, invest or save up for a beefier transmission. A tranny cooler is a must too. I ran a B&M tranny cooler with my last A4 set up. Fit nicely. I would say if you are looking to achieve 10's, a Nitrous Outlet Wet Plate Kit would get you into the 10's with ease. A 75-100 shot would be a safe shot to run with the power you are already making. Chances are your transmission won't last long with it though...
Old 09-29-2010, 02:58 PM
Eric ran a 11.4 on MT with his 3.73 geared 9" A4 with a 75 shot and full bolt-on's. You got this(he is on his second tranny and wanting to rebuild it though).
Old 09-29-2010, 03:22 PM
Make that a third tranny.... I saw it sitting down at Toms shop about a month ago getting a new trans. DOH!!!
Mike
Old 09-29-2010, 06:24 PM
Heyfred's Avatar
This is my current street/strip build. The car will run on pump gas, est mid 11 ET in the quarter and be able to drive at anytime, even cross country. The car is over built in the drive train, so in the future, if I want to up the HP/TQ I should not have durability issues.
https://ls1tech.com/forums/drag-raci...per-build.html
Here is another build you may want to look at for some ideas:
https://ls1tech.com/forums/drag-raci...itch-diet.html
Old 09-29-2010, 06:54 PM
alright so tranny with a cooler is the next step looks like most people think this is the best thing to do next... and then ill grab up the wet plate and should be good to go after that... im pretty excited to get the car on a strip with what i have currently (after its done still waiting to put the car back together after the head swap) Ok here is another question... should i even install the TC if im gonna eventually rebuild the tranny or should i just wait to throw it in... i Mean its not a hard or expensive job since im going to do it myself and already have all the parts ya know? So should i just wait till the next tranny ? Anybody know some one that wants a set of stock ls1 heads off my 98 in good condition? They have 90k on them no cracks or anything in them. Would be great to mess around with i would imagine... i dont want hardly anything for them.
Quick Reply: So what should i start saving for? Suggestions plz
