Motor ready to drop
Motor ready to drop
With a lot of help from Don & Ellis yesterday (+ 10 hrs of work) I got my motor ready to drop in the car. The cam is in, the heads are on, the rocker arms are setup, the covers & pan are lined up. All-in-all a very good day.
Go here to see the latest pictures & click on the Stroker / Blower motor album
http://community.webshots.com/user/wahusker
HEY, you guys stay away from my motor/tranny with that pink paint!!!
The compression ratio should be around 9.3:1. At least that is what we figured with the piston dish, head gasket & stock heads. If Ellis would ever tell me what the combustion chamber #s ended up being, I would know for sure.
Did I say "her"?
And again, the est time for it to go in is somewhere around a month away. I still need to buy the balancer & flexplate, I want to get the exh reworked so it's easy to take apart, and next weekend we're putting the cage in.
Did I say "her"?
Originally Posted by WAHUSKER
Did I say "her"?
Sorry mark
Originally Posted by CHarris
Mark, Ellis has the crank pinning kit all ready to go now. All you need is some steel bar cut to the right length. It'll work perfect
Originally Posted by Ryan K
Don't forget to Drill and tap the top alternator hole in the front of the block BEFORE you drop it in...
Ryan
Ryan
Funny boy....see if I ever help you install your motor or tranny again.
This was posted by Reckless in another thread:
You will just need a good drill, a really good bit that is just slightly smaller than the tap which is a metric (M10 x 1.50).
-Insert the bolt for the hole you do have and snug it with you fingers so the bracket is where you want it
-Use a punch to mark where to drill
-Remove bracket
-Drill out and tap using plenty WD40
-Blow out or use a bristle brush or similar
-Ready to go!
Looks like I will be missing 1 bolt. No place to put in on a 6L. I hope that isn't an issue with a blower.
-Remove bracket
-Ready to go!
Stop teasing us Ford guys
Mark, when I saw the topic MOTOR READY TO DROP, I thought allright, a GM guy is going drop his motor, this ought to be good to watch. Only to find out, your dropping it into your car. :-)) Seriously, it sounds like your going to have an real animal under the hood! Hope all goes well.
-Kent-
-Kent-
