Northwest Members WA, OR, ID, MT, WY, SD, ND
Local BBC
Old 02-27-2006, 11:20 PM
CHarris's Avatar
Default Local BBC
.. for sale.
It's got the following highlights:
1973 454 block bored .060 over, 4 bolt caps and line bored. Lifter Valley is polished and has screens and magnets epoxied in.
427 steel crank (.010/.010 and crossdrilled)
GM Truck rods that have been shot peened, polished, sized, and balanced (sizing and balance by Bliss in Spanaway)
TRW Forged Dome pistons L2308AF060 (full floating pins) These have a 50cc dome and should be 11.66 to 1 compression with 117cc heads.
Manley true roller timing set with torrington bearing
GM 781 Iron oval port heads ported by PDQ.
2.19/1.88 stainless valves.
Comp Products electro-polished congo roller valve spring (for big mechanical roller cams).
Trick titanium retainers with 10 degree locks.
Pushrods .080 3/8 (Comp Products/Howards Cams ultimate)
Schneider Custom Mechanical Roller Cam (requires bronze gear on distributor!) I:266@.050/E:270@.050 Lobe sep: 108 Intake centerline:106 Valve lift: I -.655 ; E - .663
Schneider light weight solid roller lifters
Oil pan is a typical Moroso knockoff that has the gold rear sump pan that flares out slightly to each side.
ARP Main and Head studs
Holley strip dominator intake
All in all, a VERY good deal for only $1450.
Let me know if you are interested. I'll be happy to get that 6 square foot area of floor space back
Old 02-28-2006, 12:02 AM
howierd42's Avatar
So I take it you are not selling the rights to the Brittish Broadcasting Company?
Old 02-28-2006, 12:05 AM
CHarris's Avatar
Sure am... right here:
Rights to BBC for sale: $1 million dollars. Really makes the other BBC seem like super deal doesn't it?
Old 03-01-2006, 11:12 AM
GEARHED's Avatar
I'm still partial to SBC's, like a 390
Old 03-01-2006, 04:07 PM
pro1955's Avatar
No substitute for cubic inch.
Old 03-01-2006, 07:59 PM
CHarris's Avatar
Apparently not around here... :crickets chirping:
Old 03-01-2006, 10:06 PM
1970camaroRS's Avatar
Want a procharger p-600b? I blew up my 350 and a BBC wouldn't be a bad upgrade.
Old 03-01-2006, 11:17 PM
CHarris's Avatar
If you can sell that supercharger, I'll be happy to sell you my BBC. I just don't have need of a supercharger any longer.
Old 03-23-2006, 07:48 PM
CHarris's Avatar
Still available for someone wanting an old school brute setup!
Old 03-24-2006, 10:19 AM
99blancoSS's Avatar
Wish I had a Chevelle. Not a bad price.
Old 03-26-2006, 03:07 AM
TimTaylor75's Avatar
Man, if I were on the west coast, I'd be all over this.
