Northwest Members WA, OR, ID, MT, WY, SD, ND
Lug nut rule
Old 08-17-2006, 08:46 AM
Ackattack1's Avatar
Default Lug nut rule
Does anyone know what kind of rules the NHRA has on lug nuts? I've only raced with stock wheels and no one has ever said anything about them, but now I'm going to be racing the pickup this weekend and don't want to get turned away because of them.
Right now the studs don't extend quite all the way through the nut. It seems (from memory) that there either has to be a min of 1 thread showing, or thread engagement equivalent to the size of the stud (1/2" in my case). But I can't remember.
Thanks
Derek
Old 08-17-2006, 09:04 AM
TwoFast4Lv's Avatar
The threaded portion of the stud MUST extend into the 'Hex' portion of the nut at least a distance equaling the width of the stud.
So a 7/16th stud must engage the threads IN the hex portion of the nut at least 7/16ths os an inch
I hope this helps
Old 08-17-2006, 09:34 AM
Rockin C Racing's Avatar
Correct. This rule is only in place if you are running slicks. If you are on street tires, it does not apply.
Ackattack1's Avatar
guess I'll have to do some measuring to make sure the ones I have are legal....got to get some open lug nuts for the front anyways.
Old 08-17-2006, 11:18 AM
LSxChevelle's Avatar
You running street tires?
Old 08-17-2006, 11:41 AM
Ackattack1's Avatar
Street tire
so I'm good with my regular closed end lug nuts....correct?
Old 08-17-2006, 11:43 AM
Correct
Old 08-17-2006, 01:15 PM
99blancoSS's Avatar
Closed please, we dont need anymore nuts showing after that last photo
Quick Reply: Lug nut rule
