Best course of action?
Old 06-14-2009, 01:30 PM
BlutVonSchwachen's Avatar
Default Best course of action?
I have the following damage on the front side of my passenger side door:
What are my options aside from taking it to a body shop or buying a new door?
Old 06-14-2009, 02:59 PM
Duffster's Avatar
fiberglass after sanding an area about 4-6 inches surrounding it so it can 'bite' into the roughed area. Few layers of glass on back side too for strength. Minor imperfection filling with bondo after shaping and then glaze putty fill those minor imperfections. . . You'll have an area around 1ft by 1ft needing repainted. . . .Do the work yourself... About 3-4 hours TOTAL for a newbie and save a few hundred dollars.
Old 06-14-2009, 05:48 PM
cvalliere's Avatar
You can't use fiber glass, it won't adhere. The door skins aren't made of fiberglass, they are made of SMC ( Sheet Molded Compound). To be honest, if you want a repair that will actually be perminant you'll have to atleast put a door skin on it.
Old 06-14-2009, 06:54 PM
Duffster's Avatar
Then get a kit for SMC repair. . .
Old 06-14-2009, 06:56 PM
So basically itll be easier to just find a junk camaro and get a new door...
Old 06-14-2009, 06:58 PM
Duffster's Avatar
unless painting is required, then save money and fix it yourself
Old 06-15-2009, 03:48 AM
flirtnwithdisaster's Avatar
Default door
It apperars that painting is going to be a must. I repaired a door simular by cutting a section off of another door that had been damaged and panel bund in place. Takes a little time but looks a lot nicer. other than that replace the door for 150 bucks
Old 06-18-2009, 10:17 PM
Reliablevetteman's Avatar
To be honest, this door can be repaired. I would say for someone not familar with smc repair it will be time consuming. 3M makes a product called 8115 pannel bonder. I use this product to bond new smc pannel on vettes and repair damaged sections. It takes 24 hours to set and can be a challenge to get used to but makes for a exellent repair.
Old 06-19-2009, 10:23 PM
metalman's Avatar
Wink
You have to be careful with panelbond because it will "move" under different rates when the temperatures change causing the repair area to become visible. I agree to use an SMC repair compound.
